suck fumes1548534743 Posted November 21, 2013 Share Posted November 21, 2013 I run the 4 link and it works perfect for me. If the 4 link sucked that bad then ford wouldn't have invested a ton of money in development into it and wouldn't have left it on 3 generations of mustangs. It works great if you have the car setup correctly! Quote Link to comment Share on other sites More sharing options...
soundguydave1548534741 Posted November 21, 2013 Share Posted November 21, 2013 The new stock upper rears are over $200.00 per set now. I think there is only one company producing the stock type unit. I went away from the PM3L this year. The car is way different and has to be driven different than with the PM3L but I like it way better. I don't know how long I will get out of the uppers now running the four link but running the PM3L I would go through a stock upper in two weekends. JJ This is disturbing to hear. I hadn't heard that the control arms weren't avail or in short supply. Who is the only mfr that's left? AFAIK, there IS no current mfgr. Max Motorsports bought all the back stock when Ford disco'd them from the dealer parts supply chain. Not available through Ford Racing, either. At least, that's my undertstanding. Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 21, 2013 Share Posted November 21, 2013 The stronger arm is not the goal but rather an arm with a non-binding bushing. It isn't the arm that fails but rather the body mount and that can't be fixed easily. It you have a rubber bushing in the arm and deflect that arm side to side, that twist load is transmitted to the mount and results in the mount failing. If there was a bearing there, the twist load goes away. Since bushings are free and your logic is centered on the non-binding bushing isn't this a better option than allowing beefy control arms?: http://www.steeda.com/store/steeda-spherical-upper-control-arm-bushings-for-1979-thru-2004-ford-mustang.html And along Aaron's line of thought, if the control arms are beefed up and the mounts are beefed up, where will that stress point move to? PH bar? Diff mounting? Now those need beefed up? It seems to me that replacing a control arm is the least evil of the choices, and easiest to maintain (i.e. spare in the trailer). You keep focusing on the beefing up and that is not the goal. I focusing on the reduction of twist the chassis mounts see. Nothing else. Quote Link to comment Share on other sites More sharing options...
soundguydave1548534741 Posted November 21, 2013 Share Posted November 21, 2013 I run the 4 link and it works perfect for me. If the 4 link sucked that bad then ford wouldn't have invested a ton of money in development into it and wouldn't have left it on 3 generations of mustangs. It works great if you have the car setup correctly! Oh, it does work well, if you're out getting groceries or hitting the dragstrip. Throwing it into a corner is another matter. We get grinding noises in left turns (no witness marks mrom tire contact), and short of throwing new arms at it repeatedly, it stll comes down to roll-induced bind. Using bushing torsional deflection is just not the right way to locate an axle laterally. As for Ford leaving the design alone, yes, they did, but I would bet BIG money that it was a cost-based decision, and not performance-driven. 90% of the people that buy Mustangs don't race them. And 90% of those that do, don't turn in their chosen form of motorsport. Quote Link to comment Share on other sites More sharing options...
cozog1548534733 Posted November 21, 2013 Share Posted November 21, 2013 The stronger arm is not the goal but rather an arm with a non-binding bushing. It isn't the arm that fails but rather the body mount and that can't be fixed easily. It you have a rubber bushing in the arm and deflect that arm side to side, that twist load is transmitted to the mount and results in the mount failing. If there was a bearing there, the twist load goes away. Since bushings are free and your logic is centered on the non-binding bushing isn't this a better option than allowing beefy control arms?: http://www.steeda.com/store/steeda-spherical-upper-control-arm-bushings-for-1979-thru-2004-ford-mustang.html And along Aaron's line of thought, if the control arms are beefed up and the mounts are beefed up, where will that stress point move to? PH bar? Diff mounting? Now those need beefed up? It seems to me that replacing a control arm is the least evil of the choices, and easiest to maintain (i.e. spare in the trailer). You keep focusing on the beefing up and that is not the goal. I focusing on the reduction of twist the chassis mounts see. Nothing else. check ur email. Quote Link to comment Share on other sites More sharing options...
BADVENM Posted November 21, 2013 Share Posted November 21, 2013 I run the 4 link and it works perfect for me. If the 4 link sucked that bad then ford wouldn't have invested a ton of money in development into it and wouldn't have left it on 3 generations of mustangs. It works great if you have the car setup correctly! Oh, it does work well, if you're out getting groceries or hitting the dragstrip. Throwing it into a corner is another matter. We get grinding noises in left turns (no witness marks mrom tire contact), and short of throwing new arms at it repeatedly, it stll comes down to roll-induced bind. Using bushing torsional deflection is just not the right way to locate an axle laterally. As for Ford leaving the design alone, yes, they did, but I would bet BIG money that it was a cost-based decision, and not performance-driven. 90% of the people that buy Mustangs don't race them. And 90% of those that do, don't turn in their chosen form of motorsport. Hmmm, you mentioned grinding noises when turning left. At the beginning of the race season last year I started getting a grinding noise behind my seat somewhere in the middle of the car but slightly back by the axle. I thought my driveshaft was rubbing on the safety loop but no signs of that. I was getting the grinding noise on hard fairly high-g right turns, not so much on left but I cant completely rule it out. I'm wondering if that noise I'm hearing (last year and this year) is related to the binding issues. I'll need to get under the car and check that out a bit closer. Quote Link to comment Share on other sites More sharing options...
soundguydave1548534741 Posted November 21, 2013 Share Posted November 21, 2013 Ours sounds like rear tire rub, but with no evidence left behind... I'm putting it down to one or more UCA bushings being shot enough to transmit "normal" NVH vibrations from the axle into the tub. Ours is only on lefts, and only at high load. One ex-Bondurant car in our region does the same thing... The Bondurant folks said "that just lets you know you're pushing hard enough. " Quote Link to comment Share on other sites More sharing options...
BADVENM Posted November 21, 2013 Share Posted November 21, 2013 Ours sounds like rear tire rub, but with no evidence left behind... I'm putting it down to one or more UCA bushings being shot enough to transmit "normal" NVH vibrations from the axle into the tub. Ours is only on lefts, and only at high load. One ex-Bondurant car in our region does the same thing... The Bondurant folks said "that just lets you know you're pushing hard enough. " Makes sense, last year was the first year I really started getting comfortable in the car and pushing it hard. Pushed it even harder this year and we added max width tires and wheels as well as bigger brakes. We were looking for tire rub too, ours is confined to the fronts. I have some video in which you can hear it. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted November 21, 2013 Share Posted November 21, 2013 The physics of the stock 4-link just flat suck. It works fine in pure longitudinal axis motion (acccel/brake), but quite literally the instant you put the car in roll, the upper arms are in bind. This puts tearing stresses into the bushing material as well as the mount. Going to a higher-durometer bushing (poly) only exacerbates the problem, and while sphericals would help, the real problem is with the stamped sheetmetal arms themselves, as well as the geometry of the design. Exactly. Also, as was explained to me, when the axle rotates about the longitudinal axis during cornering, the geometry involved in the angled upper arms causes one upper arm to go into compression while the other goes into tension (one arm tries to get longer, while the other tries to get shorter) Therefore, spherical bearings are not the ultimate answer in eliminating all of the bind induced from cornering. While some portion of the bind is due to the twisting motion that could be eliminated with spherical bearings, they won't eliminate the tension/compression issue. The best solution for this that I've seen was from a company that went out of business several years ago. I found an example of it not too long ago, but have been struggling for the past couple hours because I've been unable to find it again. Maybe another fox old-timer remembers it also and can help out. Anyway, it consisted of two brackets, one that fit between the upper rear control arm mounting ears on the rear axle, and another U-shaped bracket that mounted between the upper rear arm mounting points on the chassis side. These two brackets were connected by a single upper control arm with spherical bearings on either end. This arrangement end up being VERY similar to the current setup on the S197 Mustangs. With a single upper arm located at the center of the axle, the bind from twisting and from compression/tension is totally eliminated. It also eliminated much of the stresses encountered from converting to something like the PM3L. This setup also needs either a watts-link or a panhard bar to locate the axle horizontally. If I was going to completely redo the rear suspension in a fox Mustang, this would be my preferred setup instead of going with a torque arm and coilovers. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted November 21, 2013 Share Posted November 21, 2013 If the 4 link sucked that bad then ford wouldn't have invested a ton of money in development into it and wouldn't have left it on 3 generations of mustangs. You have to remember this design came about as a result of Ford's efforts to downsize cars to improve fuel mileage and to reduce the number of different chassis they were using at the time in order to save money in the late 79s and early 80s. Ford milked the FOX chassis for all it was worth as it was eventually used on thirteen distinct models, of which the Mustang/Capri was the sportiest and the Mustang was the last one still using it in a modified form 25+ years later. Ford left it along because it worked for what most people wanted from it probably 99+% of the time. And for every model and year they could keep using it, that was one more model and year they didn't have to spend additional R&D money. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted November 21, 2013 Share Posted November 21, 2013 Ours sounds like rear tire rub, but with no evidence left behind... I'm putting it down to one or more UCA bushings being shot enough to transmit "normal" NVH vibrations from the axle into the tub. Ours is only on lefts, and only at high load. One ex-Bondurant car in our region does the same thing... The Bondurant folks said "that just lets you know you're pushing hard enough. " Makes sense, last year was the first year I really started getting comfortable in the car and pushing it hard. Pushed it even harder this year and we added max width tires and wheels as well as bigger brakes. We were looking for tire rub too, ours is confined to the fronts. I have some video in which you can hear it. To clarify, the only tire rub we can find is in the front. We don't see anywhere the tires are rubbing in the rear, but that's exactly what it sounds like. We had a situation early on when we first built the car where the transmission mount was worn out enough that the tail of the transmission was shifting and the driveshaft balancing weights were hitting on the driveshaft loop bolt heads. It almost sounds like that, but much further back towards the rear axle. However, there is no evidence of contact around the driveshaft. We even had our real mechanic open up and inspect the differential to see if there was anything going on in there. The only thing he could find was that the buttons on the end of the axle shafts where they contact the spider gear shaft had worn down enough that there was a concern there might be too much end play in the axle shafts which might affect the rear brakes, and that the integrity of the area at the end of the axle might be compromised and the c-clips might eventually come loose. We ended up replacing the fox length axle shafts with SN95 length axle shafts as part of our effort to maximize track width. Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted November 21, 2013 Author Members Share Posted November 21, 2013 As evidenced by the discussion in the prior couple of pages I think you can see that the jury is still out on the mustang rear upper arms. It sounds reasonable, but certainly more discussion is needed so taking the time and not jumping to a rule change is a good decision. When we reach a more definitive stance then we can change the rule (if thats the direction we choose to go). As for the wheel weight value...that .0 was on the "to do" list but I overlooked it. It'll be in the first revision. Quote Link to comment Share on other sites More sharing options...
Den341548534727 Posted November 21, 2013 Share Posted November 21, 2013 It would be interesting to see if someone could get video of the upper control arms during race conditions and see exactly what it going on. Quote Link to comment Share on other sites More sharing options...
BADVENM Posted November 21, 2013 Share Posted November 21, 2013 It would be interesting to see if someone could get video of the upper control arms during race conditions and see exactly what it going on. Great idea. MHISSTC has some great keyfob cameras, we could put one near each control arm then splice the video together to watch both at the same time and see whats going on. Quote Link to comment Share on other sites More sharing options...
ShadowBolt Posted November 21, 2013 Share Posted November 21, 2013 The best solution for this that I've seen was from a company that went out of business several years ago. I found an example of it not too long ago, but have been struggling for the past couple hours because I've been unable to find it again. Maybe another fox old-timer remembers it also and can help out. Anyway, it consisted of two brackets, one that fit between the upper rear control arm mounting ears on the rear axle, and another U-shaped bracket that mounted between the upper rear arm mounting points on the chassis side. These two brackets were connected by a single upper control arm with spherical bearings on either end. This arrangement end up being VERY similar to the current setup on the S197 Mustangs. With a single upper arm located at the center of the axle, the bind from twisting and from compression/tension is totally eliminated. It also eliminated much of the stresses encountered from converting to something like the PM3L. This setup also needs either a watts-link or a panhard bar to locate the axle horizontally. If I was going to completely redo the rear suspension in a fox Mustang, this would be my preferred setup instead of going with a torque arm and coilovers. I saw this set-up once also. The company did go out of business. It would be a great way to go for the Mustang without going to the torque arm. I will try to find it again. I would assume you could still tear out the upper mounts. I was told the stock upper arms are all gone after MM sells what they have. I don't know when that will be but the price has doubled in the last two years. We will have to address this issue at some point. I (like Aaron) think the four link with the sphericals in the axle side is not bad. For me it is way better than the PM3L was. I had ripped out the upper right mount running the PM3L and welded it all up. I was surprised to tear the left upper out running the stock four link. JJ Quote Link to comment Share on other sites More sharing options...
ShadowBolt Posted November 21, 2013 Share Posted November 21, 2013 double post Quote Link to comment Share on other sites More sharing options...
sriner Posted November 21, 2013 Share Posted November 21, 2013 The best solution for this that I've seen was from a company that went out of business several years ago. I found an example of it not too long ago, but have been struggling for the past couple hours because I've been unable to find it again. Maybe another fox old-timer remembers it also and can help out. Anyway, it consisted of two brackets, one that fit between the upper rear control arm mounting ears on the rear axle, and another U-shaped bracket that mounted between the upper rear arm mounting points on the chassis side. These two brackets were connected by a single upper control arm with spherical bearings on either end. This arrangement end up being VERY similar to the current setup on the S197 Mustangs. With a single upper arm located at the center of the axle, the bind from twisting and from compression/tension is totally eliminated. It also eliminated much of the stresses encountered from converting to something like the PM3L. This setup also needs either a watts-link or a panhard bar to locate the axle horizontally. If I was going to completely redo the rear suspension in a fox Mustang, this would be my preferred setup instead of going with a torque arm and coilovers. I think the part you are thinking of is Evolution Motorsports (EVM) Tri-link set up. But as previously mentioned, they went out of business. But other people have designed their own three link set-up. But CMC isn't about building your own suspension (thats more of AI or AIX), but improving through aftermarket. Here is what I don't understand. The wild rides upper and lower S-Box replacement kit is now allowed, good choice, and costs $650 not including installation cost. The MM torque arm for racing costs $450 not including installation cost. Plus no more upper control arm costs. Yes you need subframe connectors and a panhard bar or similar. But those are already allowed modifications. I understand the reasoning that weight and power might need to be adjusted for the mustangs, since this is a major improvement in handling. But from a cost standpoint I don't see it. This should be in a different thread, but this is where the discussion is currently at. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted November 21, 2013 Share Posted November 21, 2013 I think the part you are thinking of is Evolution Motorsports (EVM) Tri-link set up. But as previously mentioned, they went out of business. But other people have designed their own three link set-up. But CMC isn't about building your own suspension (thats more of AI or AIX), but improving through aftermarket. That may very well be the item and manufacturer I remember, but something seems a little different. It's been a while, so that's probably the right one. Without the manufacturer website being available, I'm having to rely on pictures and forum discussions that have been previously posted and are still available to use as reference. It seems many folks agree that this setup has great potential for improvements over the stock geometry without making the commitment to go with a full Torque Arm and coilover setup, but a vocal minority seem to have had issues with the parts and the tearing of the floor around the mounting points. Those issues seem to be related mainly to drag racing and high horsepower rather than with road course use. It seems to me the concept is sound, but that it may require a little better engineering to get it right. EDIT: The best place I could find anything on this unit was at Corner Carvers. CLICK HERE for the 10 page thread. Quote Link to comment Share on other sites More sharing options...
D Algozine Posted November 22, 2013 Share Posted November 22, 2013 Anyone else see the 800lb gorilla in the room ? Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted November 22, 2013 Share Posted November 22, 2013 Anyone else see the 800lb gorilla in the room ? Which one are you looking at? Quote Link to comment Share on other sites More sharing options...
D Algozine Posted November 22, 2013 Share Posted November 22, 2013 Anyone else see the 800lb gorilla in the room ? Which one are you looking at? Torque arm. The solution to all of these Mustang rear suspension problems has already been invented. It's not that expensive and its a proven solution. Quote Link to comment Share on other sites More sharing options...
ShadowBolt Posted November 23, 2013 Share Posted November 23, 2013 Anyone else see the 800lb gorilla in the room ? Which one are you looking at? Torque arm. The solution to all of these Mustang rear suspension problems has already been invented. It's not that expensive and its a proven solution. The Camaro drivers are sure the torque arm will make CMC an all Mustang series like AI. It will never happen. I just purchased the Wild Rides S-Box to fix my upper mounts. This (tearing upper mounts out) is going to become a non-issue. The S-Box came in today. This thing is a piece of art. As the owner of a precision sheet metal shop I can tell you it is very well made and we will never tear these mounts out. I did not measure it yet but it looks like it is made out of at least 10 ga and maybe 7 ga. 10 ga is .134" and 7 ga is .179"! JJ Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted November 23, 2013 Members Share Posted November 23, 2013 The torque arm bolts to the seat belt holes, right? All it does is maintain pinion angle, right? Then you'd need a panhard bar? How exactly would it change the characteristics of the car save for the rear end not binding and tearing shit up? Would the Mustang drivers then suffer the same destructive axle hop on a bad downshift? Quote Link to comment Share on other sites More sharing options...
Tom P Posted November 23, 2013 Share Posted November 23, 2013 The torque arm bolts to the seat belt holes, right? http://www.maximummotorsports.com/content/install/pdf/rear_susp/MMTA1-2r2.pdf Quote Link to comment Share on other sites More sharing options...
BADVENM Posted December 27, 2013 Share Posted December 27, 2013 As evidenced by the discussion in the prior couple of pages I think you can see that the jury is still out on the mustang rear upper arms. It sounds reasonable, but certainly more discussion is needed so taking the time and not jumping to a rule change is a good decision. When we reach a more definitive stance then we can change the rule (if thats the direction we choose to go). As for the wheel weight value...that .0 was on the "to do" list but I overlooked it. It'll be in the first revision. When will the revision be out? Quote Link to comment Share on other sites More sharing options...
