D Algozine Posted October 2, 2014 Share Posted October 2, 2014 Any thoughts or input ? Summary: Limit Carb car revs, just like all of the EFI cars. Not sure what the max RPM should be, but 6200 is the highest of the EFI engines. You can easily rev well past 6500 safely, besides how would anyone ever confirm if the internals have been upgraded. And the only benefit to upgraded internals from a performance standpoint would be high revs. Of which only a carb car can take advantage of. Higher revs can be a performance advantage with less shifts and better use and flexibility in various racing conditions. Could be used to a significant advantage for someone interested in pushing the boundaries. No limit on anything within the CMC rules, doesn’t match the rule set. A simple chip in the ignition box is fair and simple to police. There are a couple different versions of these http://www.jegs.com/i/MSD-Ignition/121/8728/10002/-1?parentProductId=#moreDetails Would this be a simple , inexpensive ( $ 125 ) method? ---4) Reasoning for change MUST include at least 1 of the following: ---------->a) Will decrease series cost because… Possibly less engine wear / breakage with a rev limit ---------->b) Will increase driver safety because… None ---------->c) Will promote series growth because... Better level the playing field. Being able to rev to 6500 to 7000 is an advantage. Less shifts for certain locations on at some tracks. Wider range of RPM’s allows more flexibility in certain driving situations . Will make it equal to EFI cars ---------->d) Will improve competition because… Same as above ---------->e) Will provide more clarity because… Carb revs are currently open , which in a restrictive class, doesn’t match the rest of the rule set Quote Link to comment Share on other sites More sharing options...
FBody383 Posted October 3, 2014 Share Posted October 3, 2014 I thought rev limiters were already allowed as rev limiters - I always wanted to wire up one clutch in/first gear selected as launch control. Quote Link to comment Share on other sites More sharing options...
Adam Ginsberg Posted October 3, 2014 Share Posted October 3, 2014 Any thoughts or input ? Seriously?? When was the last time you read the rules? 7.23.2 Any rev limiting device may be used provided that is its only function. It's been there since 2007. Quote Link to comment Share on other sites More sharing options...
D Algozine Posted October 3, 2014 Author Share Posted October 3, 2014 Any thoughts or input ? Seriously?? When was the last time you read the rules? 7.23.2 Any rev limiting device may be used provided that is its only function. It's been there since 2007. LOL Where's the love Read my post again! Perhaps it's not clear The questions is " should carbs cars have a maximum rev limit" ? Currently they do not have a max, like all of the EFI cars do Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 4, 2014 Share Posted October 4, 2014 Dave A - I understood your point from the get go. I pointed this out a few years back. I am in favor. More detailed post to come. Hate typing on my phone. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 4, 2014 Share Posted October 4, 2014 By not having a rev limiter in place, there is a chance to extend the RPM's in places allowing you to not have to shift up between corners when those w/ limiters have to. I have myself rode the limiter in places as it was faster than shifting up one and right back down one. So while the motors power may be dropping off, there is an advantage to perform less shifts per lap. For every saved upshift, there is a saved down shift (yes I know there are times when we drop down more than 2 gears at a time - but you get my point). When the motors were at the 230hp limit this was a concern, but quickly dismissed as the motors made no power in the RPM's where we were concerned. Advantage/disadvantage was quickly dismissed as a wash. Now that we have some motors w/ non-OEM cams, this can be problem. I know we don't want to remove all RPM limits as that will make folks want to spend money on non-legal internals. I would love to see this debated from both sides. Adam - ........ never mind. Quote Link to comment Share on other sites More sharing options...
CMC#11 Posted October 4, 2014 Share Posted October 4, 2014 I think this is a great rule. There is no reason IMO to not have a limiter on the carb cars with the exception that it is more $$ to spend. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted October 5, 2014 Share Posted October 5, 2014 Is 6k the consensus on a reasonable redline for any of the carbed engines? Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 5, 2014 Share Posted October 5, 2014 Any reason to not make it the same as efi cars? Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted October 5, 2014 Share Posted October 5, 2014 Any reason to not make it the same as efi cars? I'm not sure. Are the GM and Ford EFI redlines the same right now? I think the spec carb engine should be allowed to go a little bit higher than the 6200 RPM redline as given previously in the EFI setup example. I asked about what is a reasonable redline because I'm interested in knowing what the actual structural limitations are of the stock internals and hardware more so than merely transposing the limitations from an engine that is equipped with a much different air and fuel delivery system. I haven't researched the structural engineering aspect of the engines as much as I've done the math every which way with all of the different rules of thumbs regarding carb, cam, header and intake sizing, etc. Going through that exercise, it seems to me the components specifically allowed on the spec carb engines are sized on the large end of the scale, or are even slightly over-large, for the RPM and power range we're shooting for with these engines. For those components to operate properly and most efficiently, it seems to me that the max RPM allowed on the spec carbed engine may have to be a bit higher than those with an EFI setup. Something like 6500 RPM (if not higher) seems like a completely reasonable value for that setup of components. However, I want to know if it's even reasonable to think a set of stock cast pistons, crank, and connecting rods are up still up to the task using the hardware found in a basic rebuild kit. Is the additional strength garnered from using ARP hardware throughout the engine is beneficial? Or, is ARP hardware overkill if the rotating assembly isn't even up to the task? Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted October 5, 2014 Members Share Posted October 5, 2014 Those alphabet cams peak before 6,000, I myself was thinking 6,250 like EFI. . . but then again the carb'd Fords don't make the torque numbers so we throw them a bone? Then there's the Chevies. 212/222 on a 112 for the spec engine. That's more duration and less lift than an LT1 cam. Perhaps we take a peek at what carb'd guys' dyno pulls look like? We can speculate where peak power is, but not so much how quickly it falls off. Maybe we base it off of where the EFI cars' rev limit is relative to their respective peak power and sort of extrapolate to the carbs? Quote Link to comment Share on other sites More sharing options...
BADVENM Posted October 5, 2014 Share Posted October 5, 2014 Is there a way to see/compare dyno charts from an EFI Ford 302 vs a carbed 302 in our series to see if there is any advantage for either setup? Compare hp/tq for various rpm levels? I guess the same would hold true comparing similar GM setups. After I read this I think my question is similar to Supercharged111's. Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted October 5, 2014 Members Share Posted October 5, 2014 So, for example, I've lost 9.5% of peak power at 5,700 RPM compared to my peak around 5,200 RPM. Now my dynos suck, so we should definitely use a healthier car to base it off of, but this is kind of what I'm getting at with the carbs. If everyone (EFI) is losing around 10% of their peak power at their rev limit, then we just get a concensus of where the carb guys are peaking and have their rev cut be where most lose XX% of peak power. Quote Link to comment Share on other sites More sharing options...
PeteL Posted October 6, 2014 Share Posted October 6, 2014 I think we're getting a little ahead of ourselves discussing what the rev limit should be. Every engine chassis combination has advantages and disadvantages. LT1's have aluminum heads but make their torque way down low, LS1s are all aluminum and have an anvil flat torque curve but have to run 50 lbs heavier which they can put low, right and aft, the Fords have their issues making power but have a lower min weight. So carb cars have one performance advantage, an RPM limit set mechanically as opposed to electronically. Is there any evidence that carb cars are running amok and need to be reined in? Have the carbed cars been dominating at the regional or national level? The real question we need to get at is not whether a lack of an imposed rev limit is an advantage but is it an advantage that is not already counterbalanced by an disadvantage. Is there a real competitive advantage factoring everything in? First step in solving a problem, make sure there is really a problem. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 6, 2014 Share Posted October 6, 2014 If there is an issue w/ power under the curve for carbs vs EFI motors, lets address that in a different thread. That is a different problem that was is addressed here w/ the original post. The reason for the original post was to close a possible advantage created by carb cars not having a hard RPM limit vs the EFI cars having one. Regardless of power and where it is made in the RPM, I would love to have a couple hundred RPM's to use in a couple spots at my event in a few days to remove the need to short shift mid straight so I don't have to do it at the end and then right back down again .5 to 1 second later. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 6, 2014 Share Posted October 6, 2014 I think we're getting a little ahead of ourselves discussing what the rev limit should be. Every engine chassis combination has advantages and disadvantages. LT1's have aluminum heads but make their torque way down low, LS1s are all aluminum and have an anvil flat torque curve but have to run 50 lbs heavier which they can put low, right and aft, the Fords have their issues making power but have a lower min weight. So carb cars have one performance advantage, an RPM limit set mechanically as opposed to electronically. Is there any evidence that carb cars are running amok and need to be reined in? Have the carbed cars been dominating at the regional or national level? The real question we need to get at is not whether a lack of an imposed rev limit is an advantage but is it an advantage that is not already counterbalanced by an disadvantage. Is there a real competitive advantage factoring everything in? First step in solving a problem, make sure there is really a problem. Great post. Spot on. Platform parity is achieved in many ways. Quote Link to comment Share on other sites More sharing options...
D Algozine Posted October 6, 2014 Author Share Posted October 6, 2014 I don't know what the limit should be, and I don't think it should be anything that inhibits the performance of the current "standard / typical" carb'd car, however there should be a maximum limit to RPM's. My semi educated guess is more then 6200, but less than 6500. My point is not so much about solving a current problem, but more about imposing a sensible limit. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted October 6, 2014 Share Posted October 6, 2014 ...I would love to have a couple hundred RPM's to use in a couple spots at my event in a few days to remove the need to short shift mid straight so I don't have to do it at the end and then right back down again .5 to 1 second later. And I love to have the low end torque and table top flat curve enjoyed by the GM engines so I'm not forced to downshift to a lower gear to keep the engine in the power band exiting corners only to have to up-shift later. It sounds like we're equally handicapped at opposite ends of the RPM range. I like Pete L's post. Is there really a problem here that needs to be solved? I haven't seen any carbed cars dominating the series and I don't know of anybody who's cheating the series by blueprinting their engines and using forged I-beam rods in order to rev it to 8k. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 6, 2014 Share Posted October 6, 2014 Scott - show me at what rpm the LT1 has an advantage with regards to TQ. Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted October 6, 2014 Members Share Posted October 6, 2014 ...I would love to have a couple hundred RPM's to use in a couple spots at my event in a few days to remove the need to short shift mid straight so I don't have to do it at the end and then right back down again .5 to 1 second later. And I love to have the low end torque and table top flat curve enjoyed by the GM engines so I'm not forced to downshift to a lower gear to keep the engine in the power band exiting corners only to have to up-shift later. It sounds like we're equally handicapped at opposite ends of the RPM range. I like Pete L's post. Is there really a problem here that needs to be solved? I haven't seen any carbed cars dominating the series and I don't know of anybody who's cheating the series by blueprinting their engines and using forged I-beam rods in order to rev it to 8k. Don't forget there is such a thing as a carb'd Chevy 350 and that the Fords can run lighter. These cars have many, many differences so they're not exactly apples and oranges. Even with a table top torque curve it's still advantageous to wind an LT1 right to the limit. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 6, 2014 Share Posted October 6, 2014 No carbs for the 4th gens. Not allowed. Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted October 6, 2014 Members Share Posted October 6, 2014 No carbs for the 4th gens. Not allowed. I never said 4th gen. But I can see where it may have been inferred. To be clear I was referring to 3rd gen F-bodies. Quote Link to comment Share on other sites More sharing options...
ls168camaro Posted October 6, 2014 Share Posted October 6, 2014 I think we're getting a little ahead of ourselves discussing what the rev limit should be. Every engine chassis combination has advantages and disadvantages. LT1's have aluminum heads but make their torque way down low, LS1s are all aluminum and have an anvil flat torque curve but have to run 50 lbs heavier which they can put low, right and aft, the Fords have their issues making power but have a lower min weight. So carb cars have one performance advantage, an RPM limit set mechanically as opposed to electronically. Is there any evidence that carb cars are running amok and need to be reined in? Have the carbed cars been dominating at the regional or national level? The real question we need to get at is not whether a lack of an imposed rev limit is an advantage but is it an advantage that is not already counterbalanced by an disadvantage. Is there a real competitive advantage factoring everything in? First step in solving a problem, make sure there is really a problem. So as it stands a Fox can run EFI with a rev limit or a carb without it. The same exact platform so doesn't have anything to do with other chassis parity. The question is with the bigger cams, big intakes, big carbs should the carbed cars be limited on their RPM? Obviously looking at some dynos of those cars would be helpful. Doesn't really matter if they aren't running amok in CMC. IF they are able to run midpack but with an advantage over another midpack guy or a backmarker then that is a problem. I only know of two Fox's running carbs in Texas and I believe both of them have to restrict their cars power. Quote Link to comment Share on other sites More sharing options...
D Algozine Posted October 6, 2014 Author Share Posted October 6, 2014 I don't know of anybody who's cheating the series by blueprinting their engines and using forged I-beam rods in order to rev it to 8k. How would anyone know if someone hasn't spent some big money on internals and is currently spinning it up to 8k? Haven't seen an engine tear down yet, and I hope I never do. This eliminates the need for a tear down, because with a rev limit , there is nearly zero performance advantage to big dollar internals. Doesn't mean someone isn't doing it now or someone will do it in near future. There are a couple carb'd racers that have used this as an advantage. I've raced with them, and I even rented one the cars a few years ago This isn't a major item, but if there are limits on nearly every other component, engine, trans, rear end, shocks, wheels , "Rear diff covers" (had to figure out a way to work that into a post this year) etc....., why not on a carb'd engine. Quote Link to comment Share on other sites More sharing options...
MHISSTC Posted October 7, 2014 Share Posted October 7, 2014 ..."Rear diff covers" (had to figure out a way to work that into a post this year)... Although we had several in mind, we purposefully did not submit any RCRs this year.. Quote Link to comment Share on other sites More sharing options...
