Members Al F. Posted September 26, 2015 Members Share Posted September 26, 2015 To get things started on an easy track... Strut Tower Braces ---1) Dustin Mozader, Rocky Mountain Region #45, [email protected]/719-648-0594 ---2) Rule reference: #7.6.2 - One bolt in stay rod may be fitted between the upper front strut towers and between each strut tower and the firewall. The minimum distance between the center of any of the stay rod’s bolting points to the edge of the base plate for the roll cage’s 7th/8th points is 18 inches. ---3) Recommend rewording to ; One bolt in stay rod may be fitted between the upper front strut towers and between each strut tower and the firewall or wiper cowl. The minimum distance between the center of any of the stay rod’s bolting points to the edge of the base plate for the roll cage’s 7th/8th points is 18 inches. ---4) Reasoning for change MUST include at least 1 of the following: ---------->e) Will provide more clarity because... The rules reads as if it targets Mustangs. 4th gen GM cars’ firewalls aren’t very accessible and it’s much simpler to bolt the brace to the wiper cowl. In an effort to allow all platforms to utilize this modification and not draw scrutiny upon themselves, I suggest the rewording above. Quote Link to comment Share on other sites More sharing options...
