Glenn Posted October 4, 2015 Share Posted October 4, 2015 http://www.fierolt1.com/lt1_rebuild.htm Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 5, 2015 Author Share Posted October 5, 2015 I guess I'll explain my reason for posting this...... Earlier in the year I lost a motor and the cam was killed as a result. I had my engine builder source a replacement for me. He was unaware of the many different OEM cams out there for an LT1. Once on the dyno it was obvious something was wrong. W/ the same restrictor plate as the old motor has, my TQ was way, way up and my HP was way, way down. Something like 330TQ w/ 230HP. Should have been pretty close to 260hp/310TQ. Anyways I got approval from the CMC guys in Texas to run that way. The result was a normal car in the corners and a really slow car on the long straights of TWS. I was off by about 3 seconds a lap from my norm. We suspected from the first dyno pull we had the wrong cam. My gut feeling was confirmed yesterday when I finally pulled the cam (motor is out for crash damage repair). Looks like I got the "600" cam. If you have a LT1 CMC car that appears to be having issues w/ too much TQ and not enough HP, this is likely the issue. Cams for the 265 and 350 iron head LT1's have much less duration numbers and a really narrow LSA. The reality is the "600" and "799" cams are not legal as they are not F-body cams. When you can, confirm the numbers on the cam yourself. Don't trust your engine builder to know these things for you. I am finding myself educating mine now as a result. Quote Link to comment Share on other sites More sharing options...
