Al F.
2018 rules
Al F.
A couple of interesting things to be aware of rules wise...
NASA has pulled forward the deadlines for submitting and approving class rules. This is a good thing for NASA, but it leaves us with very little time before deadlines (oct 15). Luckily there really aren't many burning issues to deal with rules wise. There are a couple though, so I thought we'd run through them.
1) ignition components... cost profiles for different brands have changed, and now the aftermarket brands that we've never allowed under the notion that they were just hyped marketing are actually cheaper than the OE brands for some components, so I think we'll open those up. Specifically I'm referring to distributor caps, rotors, and coils.
2) dyno temp range...thinking of dropping the upper limit for water temp for a dyno run to be valid to decrease the amount of timing the pcm pulls due to temp. I'm not sure how problematic it'll be to do multiple runs without going over the temp limit, however.
Anyway, that's it as far as I know
Share this post
Link to post
WutApex
I mentioned this on the Texas forum but would like some discussion on being able to use the Maximum Motorsports Rear Upper Shock mount. They do attach to the OEM stock mounting point and very minutely alters the pivot point to just above the shock tower (I suspect, just as a C/C plate would up front).
There's no performance benefit; it just allows the removal of the rubber bushing in favor of a spherical to reduce deflection/friction which falls in line with "Suspension bushing material is unrestricted" (7.33.7). These seem to be a relatively cheap option for removing the rubber from the suspension components.
http://www.maximummotorsports.com/MM-Racing-Rear-Upper-Shock-Mount-for-MMD-RCxxxx-series-MM-shocks-P1528.aspx
Share this post
Link to post
Dustin M.
I want to put one together for shock mounts to the body giving unrestricted height at that end. Not much different than buying a racing shock with different travel than stock in the first place.
Share this post
Link to post
Al F.
hmmm
If there's no performance advantage then why would you be willing to spend $200? Eliminating flex from the suspension is performance enhancing, lets call a duck a duck and not kid ourselves. We've gone over this concept in depth in the past and came to the conclusion that it was not in the series' best interest. I don't see how enabling everyone to spend $200 for a small performance improvement would lead to better, safer, or cheaper racing.
Share this post
Link to post
FBody383
According to the first post, I'm probably late to the party... partly because I lost the user/pass saved for here at work.
With 2018 Nationals at COTA, I'm likely to attend. One thing I know will need review is the dash cover in the 4th gen. The originals are UV brittle and stupid expensive and really brittle.
I"ve been running a flat dash cover replacement made out of foam core poster board for years. What do you need from me to make the official request to allow for alternate dash covers that maintain a "stock" appearance? I do plan to add some vents for defrost at some point.
Share this post
Link to post
Al F.
6.1 clearly allows non OEM parts as long as the replacement does not offer any performance improvement. :D
Share this post
Link to post
FBody383
6.1 in the 2017 V1 rules is the power and weight table.
But I'm taking that as a yes, it's ok. Is it considered a "dash trim piece?" Do I need an explicit note in the logbook?
7.8.6 The OEM stock dashboard must remain intact except to accommodate the installation of the roll cage.
Structure under the dash may be removed or trimmed as long as the dashboard and steering column
remain in the OEM location and are properly mounted. Any unused dash or steering column mounted
components such as A/C controls, air bags, etc. may be removed. Openings larger than 6 square inches
that result from component removal must have a suitable metal or plastic cover. Dash trim pieces may be
substituted with suitable metal or plastic pieces
Share this post
Link to post
Al F.
Sorry, meant 7.1 of the 2017 rules. No you do not need an entry in your log book to sub a suitable dash trim cover piece.
Share this post
Link to post
