cmc38camaro
Championship Winning CMC Camaro For Sale
cmc38camaro
Share this post
Link to post
t500hps
Not available to the general public
Share this post
Link to post
cmc38camaro
Oops, let me fix that. Here the text part of it:
1987 Camaro For Sale
Championship Winning Race Car w/trailer & Spares
$15,000
2011 & 2012 NASA West Coast CMC Champion
Numerous wins and track records
Bullet proof track day car or could easily move to ST4
1987 body with 1991 aero parts
Engines & Drive train:
305 TPI roller freshly rebuilt (255 RWHP & 307 RWTQ before rebuild)
Vortec heads
Edelbrock intake base
Fresh 24# injectors
MSD wires
Hooker headers
Canton oil pan
GM lightweight flywheel
Centerforce clutch
Hurst shifter
T5 5-Speed with .83 5th gear
10 Bolt rear end with 3.42 gears
Torsen T2R differential
Brakes:
12.2” 2 piece front brake rotors
Coleman 560-100 Series 3 front calipers
Hawk DTC-60 front pads
Brake bias adjustment valve
1998-2002 4th gen rear rotor and calipers
Stainless steel brake lines
255/50-16 Toyo RA1s on 16x9 lightweight Spin Werkes wheels
Weight approximately 3000 without Driver
Aluminum Drive Line
Aluminum Front bumper Reinforcement
SMC (fiberglass) hood
Battery relocated to rear passenger butt well
1.75” DOM 6 point Roll Cage with NASCAR bars
Custom adjustable rear spoiler
Suspension:
Koni adjustable shocks: double front and single rear
36mm hollow front swap bar
22mm rear sway bar
850# front springs, 200# rear springs
Edelbrock Strut tower Brace
J&M Caster/Camber plates
Sub frame connectors
Unbalance Engineering Lower control arms
Tubular Panhard bar
Cross weights to 50/50
Trailer:
1999 20’ Haulmark Thrifty hauler
Built in workbench with Tire rack
E-Track on side walls
Floor and walls are painted
Cork board & White board
2 spare tires
Comes with load leveling hitch
Spares:
4 255/50-16 RA1s on 16x9 Spin Werkes wheels, tires good for practice
4 255/50-16 RA1s on 16x8 rear offset GTA wheels, tires good for rain
2 255/50-16 RA1s not mounted, never used
2 255/50-16 RA1s on 16x8 front offset GTA wheels, tires are worn out
32 & 34mm front sway bar
21 & 23mm rear sway bars
800 & 900 Front Springs
175# Rear Springs
081 TPI heads
Stock TPI intake base
Distributor, ECM, coil, relays & sensors
Rear end housing, axles, T2R diff, 3.23 gear set
Coleman Series III calipers, need rebuilt
Front Hats and rotor
Master Cylinder
Flexible stainless steel brake lines
Driver’s door & fender
Front bumper cover with bumper reinforcement
1991-92 front chin spoiler
1991-92 Rear Bumper cover
1991-92 Passengers side ground effect
Deck lid & 3 rear spoilers
Torque Arm
Lead Ballast
Paint & Graphics
Only needs a few minor things to be race ready
Battery
Belts
Window net
I have many more pictures; let me know what you want to see
Share this post
Link to post
cmc38camaro
The Facebook link should work now.
Share this post
Link to post
cmc38camaro
Price reduced to $14,00 or make me an offer. I would consider hot rod or muscle car trades or who knows, hit me up.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
