mug23 Posted February 5, 2019 Share Posted February 5, 2019 I have purchased this 05 STI brand new in 2005 and turn the car into Time Attack/road race build shortly after driving it 1 year. Since than, it been a full blown track car its whole life. I blew the stock motor in 2008 during a time trail event in NHMS and I attempt to rebuild the car. I started the rebuild with Outfront Motorsport 2.5 fully closed deck motor with fully rebuild STI head by Outfront motorsports in CA but the rebuild till this day is still not completed due to birth of my 2 kids. I will not be able to complete the rebuild and therefore, it's time to part out or sell the car out right. Below are picture of its current status and parts list. I may missed some parts but 95% of all parts are brand new and never been used. Engine Outfront Motorsports 2.5 fully closed deck block with forged pistons, rod OEM nitrided crankshaft, ACL race bearing, Killer Bees oil pick tube, pan with baffle, Cosworth multi-layer head gasket, high flow OEM 12mm oil pump, ARP head studs, turn in concepts tgv deletes convert to top feed injector. Motor has 0 miles never been started. Cylinder Head 05 STI head fully rebuild by Outfront Motorsport with titanium retainers and upgraded valve springs BC 280 cam, 3 angle valve job and head porting. Engine block and head is assembled and will not separate. Sold as one unit. The engine is mate to the transmission and installed in the car. I will remove the engine if someone is interested. I can also sell engine and transmission together as one unit too. $4,500 - Engine+head Transmission 2005 STI 6 speed fully rebuild by DSG(Dent Sport Garage) with JDM 5th and 6th gear. Shorter ratio compare to USDM 5th and 6th gear. OEM STI front and center diff. 0 miles on the transmission since rebuild. The transmission is attached to the engine in the car right now. I will separate when someone is interested and purchase. $2,500 Brand new C&R STI Radiator(Discounted from C&R. They are known to produce radiator for NASCAR) Top quality. $400 ACT 6 puck light weight flywheel. Brand new release bearing. $ 300 RaceComp Engineering Tarmac II with Swift Springs 700lb front 600lb rear. I also have few other different spring rate spring included. In excellent condition since this was never driven on the streets. $2,000 Front Ground Control camber plate. Excellent condition. $350 Brakes Front Cobb/Stoptech 4 piston caliper 332mm BBK. Could use rebuild. I have rebuild kit for one side included. $1,300 Rear OEM STI $Offer JDM Spec C STI Power Steering cooler $200 Brand new Crawford Air Oil Separator v2 still in the box $300 Enkei NT03+M 18x9.5 powder coated orange mounted with Hooiser tires. Wheel may need to be re-powder coat due to brake dust baked in. $700 05 STI shell with fully professionally welded 8 point roll cage that meets SCCA and NASA spec for 3001-4000 lb 1.750” x .120” DOM tubing. $4,000 I'm sure there are many other new parts that I haven't listed and I will list them as I do an inventory. If you need something, just ask. I may or may not have it. Below are some picture of the car. Quote Link to comment Share on other sites More sharing options...
