e36 track/street car
Peter Ruggiero
 Share
Looking to sell my e36 track/street toy. Bought it with approx 86k miles on it and turned it into a fun HPDE car with the thought of doing NASA TT5 in it. Car has seen 6 track days with the rest just driving it around for fun.
97 328is 90k original miles
Body and paint in good condition. You can tell the clear coat is thin in areas but still looks good.
Engine mods/maintenance:
Cold air intake
Second throttle body/traction control delete
M50 intake
Upgraded injectors
Metric mechanic valve spring kit
Custom grind s52 cams
New lifters
New chain guide tensioners and guides
New valve cover gasket
Air conditioning delete (everything forward of fire wall)
Mishimoto large radiator and electric fan
Stewart hi flow water pump
Baffled oil pan
Oil pump nut upgrade and oil pump pickup brace
Custom 2.25 stainless steel single exhaust, headers back. (sending to muffler shop this week to finish out the tips)
New camshaft position sensor
New crankshaft position sensor
New knock sensors
New O2 Sensors
Rebuilt Vanos
Brand new Bimmer world dual fuel pump kit (no more fuel starvation)
Tuned by 22RPD with everything but the exhaust made 219HP @ 6200 RPM on a mustang dyno
Suspension/brakes mods/maintenance:
ST XTA coilovers
New condor bushings all over (yes, every bushing)
It is on solid Condor transmission and motor mounts
AKG Brace kit; subframe, rtab pocket, front/rear sway bar points, strut body points
Adjustable rear camber arms.
Larger rear sway bar
E46 330/325 brake upgrade kit (new rotors on the front and I have a new set still in the package for the rears)
Stainless steel brake and clutch lines
Manual brake kit (no power brakes to worry about a squishy pedal)
Castrol SRF fluid
Pfc08 pads all around, brand new in front (rears have 4 track days on them)
Front brake duct kit
New driveshaft guibo and center bearing
3.64 lsd fully rebuilt (seals and bearings)
Apex 17x9 rear and 17x8.5 front with conti takeoff slicks
Second set of e46 335 rims with 245/40-17 hankook rs3.
Inside
Gutted from dash back
Half cage, custom, weld in... Cage guy told me he could make it a full cage later on if I wanted.
Omp hte r seat (1 year old)
Kirkey passenger seat
6 point harnesses (both seats)
Duracell minuature battery in the back
Carbon fiber sunroof plug
Remember no A/C
Still registered and driven on the street.
Asking 7500 obo, car is located in champions gate, fl
You can call or text me at nine-four-one-713-eight-four-0-eight
Pictures: https://imgur.com/a/gX0pQjX
Edited by Peter Ruggiero
 Share
