smart01 Posted April 24, 2019 Share Posted April 24, 2019 Selling Cosworth BDH Engine,The engine has been in a small race car (Lola). recently rebuild with the following new parts: All bearings, new pistons, camshaft, camshaft carrier (casing?) incl the tapets (?), waterpump, timing belt, ignition parts and so on. The engine is an original vegantune BDH dry sump. The exhaust pipe is straight, After the rebuild only 20 kilometres test drive, The pistons diameter is 83,65 mm. Asking $8500 Quote Link to comment Share on other sites More sharing options...
BuyMyFordGT Posted May 17, 2019 Share Posted May 17, 2019 Did you do an engine dyno ? Quote Link to comment Share on other sites More sharing options...
