rex_boy Posted June 27, 2019 Share Posted June 27, 2019 (edited) Time to let my stuff go. Car and Trailer $13,000 (Will separate trailer and car) ENGINE Rare B18C5 Race Engine Cast by Honda for Realtime Racing Stamped RTR-16 built by famous Audi Racer/Mechanic Michael Galati (stamped) JDM Type R Pistons (P73-00) 11.1CR Oversize 25 JDM Civic Type R Rods JDM Civic Type R Camshaft with Type R Dual Valve Springs JDM Civic Type R N1 Crank Pulley Skunk 2 Adjustable Cam Gears ARP Cylinder Head Studs Type R Intake Manifold and 70MM Throttle Body AEM Adjustable Fuel Pressure Fuel Filter Mounted Pressure Gauge DC Sports Cold Air Intake Stainless Steel Cone Filter Quaife Limited Slip Differential Syncrotech built JDM J1 Transmission with brass syncros and 4.71 final drive B-Series to EF linkage Exedy Clutch and ACT Lighten Flywheel with ARP Bolts Raxels Hybrid Axels OPM Hardened 4X100 Wheel Hubs Power-Enterprise Timing Belt Hasport Mounts Zdyne Programable ECU Moreso Catch Can Moreso 5.5 Qt Oil Pan with Baffles EXAUST Hytech 4-2-1 Stainless Steel Header Flex Pipe (Cat Delete) Performance SS Cat back Super Trap Tunable Muffler SUSPENSION/HANDLING Koni Yellow Adjustable Shocks - Race Ground Control Adjustable Coil overs Eibach Springs 450F/600R Suspension Techniques 22MM Rear Sway bar Neuspeed Shock Tower Brace Neuspeed Lower Tie Bar Energy Suspension Poly Bushings Odyssey Extreme Lightweight Rear Mounted Battery BRAKES 11 In Integra Type R Rotors drilled 4X100 Integra Type R Calipers Honda 15/16 Master Cylinder Stainless Steel Brake Lines Carbotech Ceramic Kevlar XP10 Race pads WHEELS Kosei K1 15X7 – Whit Toyo Proxies R1 Race Tires – (Shaved) ATech Final Speed 15X7 Gunmetal Gray Toyo Proxies R1 Race Tires – (Full Tread) SAFETY Kirk Racing cage with door bars Custom Built Seat Mounts (both driver and passenger side) Driver Seat - Sparco Rev 2 Sparco Race Pedals ARP Extended Wheel Studs Skunk2 Open Ended Light Weight Lug Nuts G-Force – 5 Point Pro Series Camlock Harness Driver’s Window Net Triangle Roll Cage Side Net Lexan – Rear Hatch Window Lexan – Rear Quarter Windows Race-Plates Carbon Fiber Sunroof Replacement Driver Side Window Kill Switch Driver Reachable Fire Extinguisher INTERIOR Temp/Oil PSI Gauges DC Sports Short Throw Shifter JDM Type R Shift KNob Autometer 5in Tach with Shift Light PLX R300 Wideband 02 Sensor/Tuning Controller Momo Suede Leather Steering Wheel (Quick Disconnect) Longacre “Hot lap” Timer AMB Hard Wired Transponder Flex-A-Lite Switch Controlled Electric Fan Custom Welded Camera Mount on Roll Cage EXTERIOR CWest Body Kit with Whale Tail Spoiler Custom Paint Color based of 1999-2000 Civic SI Blue Vinyl Numbers EXTRAS Trailex Small Sports Car All Aluminum Trailer JDM B16A1 Short Block out Integra XSI (Running when pulled) B18C1 Ported and Polished Head Extra High Lift Camshafts B18C1 Skunk2 Intake Manifold Can provide more pictures if interested. Edited August 17, 2019 by rex_boy Added more text and pictures Quote Link to comment Share on other sites More sharing options...
TheBeast Posted August 20, 2019 Share Posted August 20, 2019 car only price? location? thank you Quote Link to comment Share on other sites More sharing options...
rex_boy Posted August 25, 2019 Author Share Posted August 25, 2019 I currently have an offer for the car. If it falls through or don't receive payment I will let you know. Quote Link to comment Share on other sites More sharing options...
rex_boy Posted September 1, 2019 Author Share Posted September 1, 2019 Sold, Car and Trailer. Quote Link to comment Share on other sites More sharing options...
