FS: BMW 330ci Track Car
JohnJoe1011
 Share
BMW 330ci 2001 coupe model, slick top no sunroof.
I bought this car in 2012 with intention of making it a dual daily driver and autocross car. The car was prepared as autocross car by Vorshlag, Terry Fair.
Weight 3036 with a 215# driver in full race gear and ½ tank of gas.
Original build is in this website.
https://vorshlag.smugmug.com/Projects/Vorshlag-E46-330Ci-DSP-Build/
Or you can go to https://vorshlag-store.com/ under Gallery and Projects.
Drove the car to several tracks for 3 years until in 2015 it became a dedicate track car trailering the car between track events. The car has never been raced, only track days or DE, at several tracks in Texas. TWS, MSR H, MSR C, COTA and ECR. Clubs are Texas NASA, LSRPCA, TheDriversEdge, EdgeAddicts, Apex Driving Academy and TWS PDS.
Currently being repair and maintained by Greg Smith Racing. Every bolt nut has been torqued to specs and adjusted every season.
Could make a nice GT2 car or SpecE46 or WRL race car.
Mileage is 206,000 KMS or 128,000 miles on chassis
Clear blue car title.
All receipts.
Contact info:
John J. Freeman
Cell phone 404 386 2730
Email [email protected]
Engine/Performance
M54 330 stock engine. When I bought the car the original engine was replace by a 2005 engine with 54K miles. I have put 18K miles on the car. Total engine mileage 72K still a good engine.
Compression 8% leak down
Ebay headers with full 3” pipe no cats.
AC deleted
Heater core not deleted
SAP=Secondary Air Pump Deleted
CamShaft Sensor replaced 2013
Exhaust sensor replaced 2013
Crank Shaft Sensor replaced 2013
MAF Sensor replace 03/2019
Valve cover gasket replaced
Oil filter gasket replaced
Idle Control Valve cleaned
Throttle body cleaned
K&N air intake cone
DISA original
CCV original
Cooling system upgraded
CSF Radiator
Mechanical Thermostat
Currently running water with a little bit of coolant
Epic Motorsport tune Rev limiter up to 6800 no restriction on top speed
Vorshlag motor mounts
Motion Motorsport UnderPanel Kit
Bimmerworld dual fuel pump.
Fuel filter replace in 2013
Refreshed power steering hoses fluids and pump 2013
Alternator voltage regulator replaced 2013
Mobil 1 synthetic currently running 15W50W changed 01/2019 Oil replaced twice a year during the racing season.
VAC Oil pump kit
Oil Pan Baffle
Dynojet at G-Speed in MSR Cresson 210 hp at wheel.
Replaced Coils 01/2019
Replaced Spark plugs 01/2019
No check engine lights.
Suspension
AST 4200 dual adjustable (Rebound and Compression)
Spring Hyperco 650# front 900# rear
Spare Hyperco front 550# and 650# rear not on car
Vorshlag Camber and caster plates
Eibach front adjustable sway bar. Eibach rear non adjustable bar
Bimmerworld rear Sub-Frame reinforcing kit done by Greg Smith Racing 2018
Powerflex Poly bushing everywhere
New diff bushing done by Greg Smith Racing
Stock control arms
Transmission:
Stock transmission 5sp
Stage one clutch from clutch master changed in 2016
Single Mass Fly wheel
Guido replace when clutch was done
Vorshlag transmission mounts
Replaced transmission support 2018
Short Shifter by UUC. Could use new bushing.
Clutch stop pedal
Differential 3:38 OS GIKEN LSD from DiffsOnline
Brakes
Stock brake calipers replace in 2016
Zimmerman front and rear rotors replace early 2019
Hawk DTC 60 all four corners
Motul 600 fluid replace 01/2019
Interior
Stripped from the back seat
Still has original wiring
Race seat: Driver is a Sabelt passenger Corboe
Radio Deleted
Original front carpet
Original dash etc.
Bolted in 4 points roll bar
6 points Turn One harness expire 2020
Hard MotorSports Cup Car side windows on car
Still have the original side windows as spare
Hard MotorSports door front panels
Still has stock front window glass and mechanism on car
MOMO steering wheel fixed
I sold the front and rear seats
Still have a lot of interior parts they will go with the sell of the car
Exterior
Topaz blue
Black Satin wrap on the top done in June 2019
Front M3 Bumper
Front M3 fenders
Rear stock rolled fenders
Paint is 8/10
Car always garage and covered
Currently running numbers and a couple of stickers they will be removed before the sell.
Front and rear tow hooks
Passenger side wheel liner replaced 2019
Wheels/Tires
2 set of D-Forge 18” wheels one set if black the other set is silver
The silver set has one bent wheel but it has been fixed.
1 set of Konig 17” wheels
Tires:
NT01 275 35/18 on the silver wheels, bought them in Sept 2018
NT01 275 25/18 on the black wheels, bought them in  Jan 2019
Hankook 235 45/18 on the 17” wheels bought them in May 2019
15mm front spacers
5mm rear spaces
  • 1 month later...
13 minutes ago, Pilot_E46 said:
Hello,
what is the asking price and where are you located?
Price is $18K obo. The car is located in Temple, Texas. Just 40 miles south of Waco and 60 north of Austin.
Thanks,
 Share
