MiataCrazy
1992 Nissan Sentra SE-R Race Car
MiataCrazy
Located in Eastlake / Cleveland Ohio 44095
3800$ – OBO
216-835-6864
Professional Build, California Car – No Rust Ready to Race  NASA ST5, ST6.  Past SE-R Cup Race History from California West Coast Nasa Region.
Photos at https://cleveland.craigslist.org/cto/d/eastlake-1992-nissan-sentra-se-race-car/6931465736.html
Dyno Sheets, Photos, Information - [email protected] or 216-835-6864
3800$ – OBO
216-835-6864
Engine / Trans
Unknown time SR20 engine but runs strong, and doesn't burn oil. Perfect Compression across 4 cylinders. Starts and runs great. Car has never had a DNF
JWT cams and cam gears
New Nismotronic SA Programmable ECU – Dyno Tuned 148-163 whp Dyno Sheets Available
Hotshot header
N1 water pump pulley (needed in any SR20 that is road racing). Large Koyo Radiator.
Quaife LSD differential With MFactory 4.78 Final Drive Ring and Pinion, B&M Short Shifter
Suspension
Dual adjustable Ground Control coil over set up with 2 1/2 inch springs. Struts could use a refresh or replacement.  Front suspension also has a bump steer and camber kit on it which helps in handling and tire wear. New Polyurethane bushings all around. ARP Extended wheel studs all around.
Brakes
Willwood big brake 11.75" kit. Rotors are from a Honda Prelude so they are cheap to replace. Pads  Hawk DTC-60 very cheap at approx.. 70$ a set and last half a season.
Safety
Robust weld in cage with gussets, main hoop lower impact bar, shock tower X, door intrustion
Sparco EVO seat, on sliders. Seat Back Brace
Longacre instruments with water and oil temp, Innovate WB02 Sensor
Fire System – 5 Liter SPA w 5 nozzles two cable pull.
Other Details:
Car comes with one set of wheels Choice of :  949 6UL 15X8 with Toyo RR tires, 4 heat cycle. , Motegi Traklites  Forged Aluminum 15X7.5 Old NT-01 Tires. Rota RB 15X7 with Hoosier Rain Tires two heat cycles.
Items needing attention – Window net and Driver Harness are out of date. Car needs a front Under tray. Heat shielding under shifter. Transponder Not Included
Comes with a truckload of spare parts. Two NASA Log Books
Race Weight – 2350lbs w 180lb driver and full tank of gas
Share this post
Link to post
