FS: New SpecMiata Wheel & Tire Package (IL)
loudes13
FS: brand new set of 949 Racing 6UL Spec Miata Max Legal wheels with new sticker Toyo RR’s
I bought these brand new from 949 and Phil’s Tire for my Specmiata to run NASA but recently sold the car. I’m eating the freight costs, the mounting and balancing, AND I’m knocking another 20% off the cost.
Set of four 949 Racing 6UL Max Legal Spec Miata Gen 4 wheels Beryllium 15x7’s with Sticker Toyo RR’s mounted, balanced, and ready to go.
The Toyo RR 205/50/15 is the spec tire for NASA Spec Miata Racing. They are also great for hpde and track days. The RR lasts much longer than Hoosier SM7. The RR also does not heatcycle as bad. I’ve been very competitive on over 20 heatcycle RR’s right down to the cords. No way you can do that on a Hoosier.
The wheels are $124 each from 949 (not even currently available) plus freight. The RR tires are $188 at both Tire Rack and Phil’s Tire plus freight and tax. That’s $1248 (before freight and sales tax) minus a 20% discount and that comes to $998.40.
Description from 949:
The Gen 4 15x7 SM has been optimized specifically for Spec Miata with a thicker outer flange and thicker inner barrel. This version is hub centric for the 89-05 Miata.
15x7
+24 offset Most aggressive offset legally allowed to meet SM track width rule
13.1 lbs lowest legal weight
4x100
Low pressure cast, flow formed monoblock construction
Knurled beads
T6 heat treated
54.1mm center bore
500kg max load rated
Double valve hole design
JWL approved
VIA certified
Durable painted Beryllium and clear coated finish
67418148_2369850480002310_83294653726211
67368050_2369850510002307_81046813786473
67313409_2369850550002303_57869741493437
67536889_2369850643335627_34678342477991
Image may contain: car
