FS 1999 BMW 328is TT/HPDE track car
Posted (edited)
Summary
Putting out a feeler for my E36 328is track car (not fully caged). Car is a multiple-class winning car built for COMSCC Time Trials, holds class records in T50, T60, SD.
Built and maintained by Wile Motorport in Walpole, MA. No longer street legal - built for Time Trials & HPDE; very good safety gear, however does not have full cage for W2W racing.
Clean title, formerly registered in MA as street car. Car is straight, but does have it's fair share of zipties; never involved in contact with a wall, barrier, or other vehicle.
Car is located in Framingham, MA.
Engine
  • M52 motor, S52 cams, M50 manifold
  • Kassel custom tune
  • Cold air intake with headlight vent
  • Refreshed bearings in 2019
  • Rebuilt head in 2019
  • A/C delete
  • VAC dual valvespring / retainer kit
  • Steward water pump
  • Mishimoto radiator
  • Aftermarket OE-equivalent exhaust
  • Removed heater core (Bimmerworld front defroster installed)
  • Bimmerworld dual fuel pumps
  • Dyno'd at 211hp/193tq to the wheels on dynojet
Drivetrain
  • Rebuilt diff 3.73 gears with 3-clutch LSD - 2019 (diffsonline)
  • Rogue Engineering diff cover
  • Rebuilt bav auto driveshaft - 2019
  • New BMW half shafts - 2019
  • OE wheel hubs & bearings - 2019
  • E36 M3 Calipers
  • PFC 08/11 pads
  • Front OE M3 Euro-floating rotors
  • Rear OE M3 rotors
  • Stainless brake & clutch lines
  • Bimmerworld wheel studs
  • Bimmerworld "Group N" motor mounts
  • Solid transmission mounts
  • Poly differential mounts
Suspension & Body
  • MCS 2-way non-remote shocks
  • 120Nm/150Nm springs (~680#/850#)
  • Vorshlag camber/castor plates
  • Bimmerworld adjustable rear control arms
  • Adjustable swaybar endlinks
  • Spherical front & rear control arm bushings
  • RTAB limiters
  • Front and rear shock tower reinforcements
  • Front subframe welded reinforcement kit
  • Rear subframe welded reinforcement kit
  • Rear swaybar welded reinforcement kit
  • Factory X brace
  • BMW LTW Strut bar
Exterior/Aero
  • Custom Wile Motorsport front splitter
  • Motion Motorsport undertray
  • MKAH Motorsports Race diffuser
  • Nine Lives Racing wing
  • Hood vent
  • Headlight and fog light delete
Weight
  • ~2800# with 1/2 tank fuel, ~75# rear ballast
  • Crossweight nearly 50% with ~190# driver
Wheels
  • Three sets of Kosei's potentially available (negotiable)
  • Set 1: 8 HC BFG R1S 245/40R17
  • Set 2: 24 HC BFG R1S 245/40R17
  • Set 3: 40% worn Michelin Pilot Sport 4S 225/45R17
Interior & Safety
  • VSR 4-point rollbar based on TC Kline jig
  • VSR sunroof delete, metal sunroof retained, does not leak
  • Cobra Evolution drivers seat
  • Sparco Rev passenger seat
  • Schroth Profi II 6-point driver belts, expired 2019
  • G-Force FIA 6-point passenger belts, expired 2019
  • Brey Krause Fire Extinguisher Mount w 2.5# bottle - passenger seat
  • Interior mostly gutted, airbags removed
  • Rogue Engineering steering wheel quick release w Sparco wheel
  • MKAH door cards, stock window internals remain
  • VAC aluminum floor pans
  • Battery kill switch
  • Window net
Edited by dtlemoine
updated camber/castor plates
Added a whole boatload of interior & exterior photos
  • 8 months later...
