redrumm3 0 Posted February 11, 2020 Share Posted February 11, 2020 (edited) FOR SALE 1995 M3 RACE CARIP #762 BMW CCAThis car was purchased as a street car in 2006 and converted to a BMW CCA IP race car. It has been developed into a proven, winning race car. Together we have won races at Sebring, CMP, Road Atlanta, COTA, Barber and Roebling Road.This is a solid winning IP race car with an excellent maintenance regimen and proven winning record.Price: $31,500.00 oboMore info and specs available on request. Located in Tampa, FL. 1995 BMW M3 Race Car Rare Factory non-sunroof car Steering wheel Momo Mod .78 Race Wheel Seat OMP HTE-R Hans 2020 expiration Belts Schroth Profi Hans expired and removed. Window Nets Schroth Window and Center Nets expired. Fire Spa FireSense Needs recertification. Suspension: Custom Turner Motorsport Bilstein Double Adjustable Special Valving from Bilstein Installed 2016 Adjustable Camber/Caster Race Plates Rear Articulating Spring Perches Poly FCAB's TC Kline Adjustable Rear Control Arms Aluminum Sparco Strut Tower Brace Front Welded Rear Tower Brace Sway bars Racing Dynamics 27mm (F) 24mm (R) Adjustable end links F&R Springs 800/800lbs F&R Differential Diffsonline 3.64 Custom 4 Clutch Polished Ring, Pinion and Bearings Rogue Diff Cover Transmission Short Shift Kit Tilton Clutch/Flywheel Kit Wheel spacers VAC Front 5mm Rear NA Brakes Brembo F40 Big Brake Kit/ Turner Backing Plates 355mm (F) slotted Stock Rear Stainless Brake Lines Pagid RS-29 Pads (yellow) F&R Stainless Caliper Pins Rear Exhaust BimmerWorld E36 Race Exhaust 3" Stainless Headers Active Autowerk e36 Long (early w/ big primaries) Intake 3.5" BimmerWorld E36 Race Intake S50 Intake Manifold 3.5" MAF Riot Racing Oversize Throttle Body Engine 36,000 mile S52 installed 2016 (OBD1) Epic Motorsports E36 M3 Race Camshaft Set Epic Tune BimmerWorld/C&R Racing E36 Oil Cooler Bimmerworld Dual Fuel Pumps Stewart Water Pump Spal Puller Fan S54 Oil Filter Housing S54 Oil Pan S54 Oil Dual Pickup Pump ARP Head Studs Injectors - oversized 24lbs Body BimmerWorld V3 Carbon Race Wing BimmerWorld E36 Carbon Splitter/Undertray Bimmerworld Carbon Dive Planes Aerocatch Hood Pins Reinforced Rear Shock Mounts Reinforced Front Subframe Reinforced Rear Swaybar Mounts Reinforced Rear Trailing Arm Pocket Factory X-brace VAC Aluminum Seat Floor Mount Adapters Turner Aluminum Rear Subframe and Diff Mounts Other C&R Racing Lightweight Aluminum Radiator Z3 1.9 Steering Rack E36 Aluminum Expansion Tank by Moroso Silicone coolant hoses SPA Design Dual Readout Gauges Wheel and Tires D-Force LTW5 17x9 ET41 Silver 2 sets Used for rains and roller APEX ARC-8 Wheels Hyper Black 17X9 ET42 2 sets Hoosier R7 245/40/17 2 sets, one new, one used mounted Hoosier Radial Wet H2O 245/40/17 one set, used a few laps mounted Misc. Spare Transmission Misc. other parts Edited February 11, 2020 by redrumm3 Update Quote Link to post Share on other sites
