Bostonbq 0 Posted February 13, 2020 Share Posted February 13, 2020 I would like to make the following rule change for the 25 hours of thunderhill rules set regarding forward-facing lights: Currently rule 4.3.2 reads “Headlight mounting is limited to the outer 12 inches of the vehicle corners. The measurement is taken from the outside edge of the front fender.” I am proposing that the rule be changed to “Headlight mounting is limited to the inside leading edge and outward of the stock front headlights, or the outer 12 inches of the vehicle corners with the measurement taken from the outside edge of the front fender. Whichever measurement is greater.” This would still limit large front light bars spanning the entire width of the front hood, but still confines the additional lights to being mounted within the zone created by the stock front headlight. I have included an image articulate the rule proposal. Quote Link to post Share on other sites
