RobotRon Posted April 15, 2020 Share Posted April 15, 2020 My car is in the progress of being modified for track use only. I have several questions that I would like to get cleared up while we have this covid 19 time. The first is that of door cards. If I still have glass in the door will door cards be required to run in HPDE2 and 3? 98 Z3 roadster image attached is before I cleaned up the wiring. Thanks Quote Link to comment Share on other sites More sharing options...
Moderators Hans D. Posted April 21, 2020 Moderators Share Posted April 21, 2020 I do not see any restriction in the rules to run without door panels, you would want to be sure there are no sharp egdes that may cause injury. I see a fixed back seat and no roll bar or means of attaching shoulder harnesses, will that be corrected before event? Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 21, 2020 National Staff Share Posted May 21, 2020 On 4/15/2020 at 7:05 AM, RobotRon said: My car is in the progress of being modified for track use only. I have several questions that I would like to get cleared up while we have this covid 19 time. The first is that of door cards. If I still have glass in the door will door cards be required to run in HPDE2 and 3? 98 Z3 roadster image attached is before I cleaned up the wiring. Thanks Your question is not exactly clear. Are you talking about door bars as part of a roll cage? Or, are you talking about the OEM door protection? You don't need them as part of an HPDE roll bar/cage, but you do for a race approved cage. If you don't have them built into a cage, you should leave the OEM ones alone. Quote Link to comment Share on other sites More sharing options...
