Members Al F. Posted June 17, 2020 Members Share Posted June 17, 2020 (edited) Clarifications and update: Engine and electric5.3L aluminum block LS1, rebuilt with only three events, intake and exhaust restrictors to allow easy adjustment to CMC legal power, aluminum 2 pass radiator with electric fan and silicone hoses, Derale oil cooler with electric fan, remote oil filter reservoir, all oil lines braided stainless steel with AN fittings, Howell Automotive engine wiring harness with all new wires run through proper fuse block and individual rocker switches: fuel, ignition, water fan, oil fan, camera, cool suit, window defog(no factory wiring anywhere), Fuel Safe 15 gal fuel cell with Holley Dinamat fuel pickup mat brand new, Walbro external fuel pump brand new, Holley fuel pressure regulator with gauge brand new, all fuel lines braided steel with AN fittings. TransmissionT-56, rebuilt with only three events, hydraulic clutch line converted to AN fittings on both sides and includes bleeder valve at the master cylinder.Rear EndDetroit True Track LSD, 4.10 gears, heavy duty axlesBrakesFront: Wilwood four piston Superlite front calipers with proper piston sizes to match master cylinder, Wilwood aluminum hubs, 12.2"" rotors (circle track rotors, very cheap replacements), custom brake cooling ducts to run 3"" diameter duct hosesRear: LT1 calipers, Wilwood aluminum hubs, Wilwood rotorsMaster cylinder and booster three events old"Suspension and Steering:Front - Global West spherical bearings on lower control arms, recent ball joint replacement, Bilstein dampers rebuilt by Unbalanced Engineering with digressive valving and tuned specifically for 4th gen with this spring rate, threaded spring collars, urethane bushings for sway bar, custom made front hubs that use 3rd Gen 1LE camaro bearings (rebuild the hub in minutes and less than $20!)Rear - Spherical rod end custom control arms and panhard bar, Bilstein dampers rebuilt by Unbalanced Engineering with digressive valving and tuned specifically for 4th gen with this spring rate, urethane bushings for sway barSteering:Custom valved power steering pump to reduce flow four events old, fluid runs through cooler built into the radiator, aluminum pump pulley, aluminum reservoir, all lines braided with AN fittings, rack is four events old.Other:Kirkey 17"" full containment seat, quick release steering wheel, water temp, oil temp, oil pressure gauges, electronic tachometer includes customizable shift lights, low oil pressure warning light, custom ballast system to easily allow adjusting weight up and down, Racepak G2X data logger and lap timer with dash display. Cool suit wiring and mount but cool suit not included. Wiring for transponder but transponder not included. YI dash camera with hard wiring.Spares:Tons of spares available, negotiable since shipping of some of this stuff might be difficult.The Bad please read :Car hit a wall going backwards in 2004 and repair involved cutting the car in half and replacing everything from the driver seat rearward. This was done at a pro shop, frame is square and car is true. The rear tubes do not land in the right best spot on the floor (just forward of the shock). Edited September 1, 2020 by Al F. updated info and pictures Quote Link to comment Share on other sites More sharing options...
Richard Pryor Posted June 19, 2020 Share Posted June 19, 2020 Hi, Al, Give me a call....831-626-7223...thanks, Richard email is [email protected] Quote Link to comment Share on other sites More sharing options...
