Engine questions....slightly confused by the rule set.
David K
 Share
Hello
I'm trying to make sure I don't leave anything on the table, so I was wondering if I could get a couple of questions answered..
Looking to build a Mustang and want to understand exactly what engine options I have available.
This gets a little more confusing where it says you can subtract 150# if using an iron block and 50# is AL block.
Which aluminum engines can I run?
If I run an iron block, can I run a dart or FMPP block for instance?
Can I run Aluminum heads?
Since it's a power to weight class, what are the limitations to engine prep?
If I decide to use the Spec Carb formula - what are the benefits?  Do I get to run more power/less weight?
Are all engines limited to 6250 RPM or just the carb spec engine?
If GM guys are allowed LS motors, can I use the Coyote?
Can V6/I4 be run? (although I think not).
Is there absolute minimum weight involved?  Or is it the lowest number in the scale?
Thanks very much.  Sorry for all the questions.
David
 Share
