National Staff Aldrin V. 18 Posted December 9, 2020 National Staff Share Posted December 9, 2020 (edited) Here is where you will find the 2021 Toyo Tires Contingency Program Decal Guidelines. These guidelines are for SPEC TIRE CLASSES ONLY! Open Tire classes are NOT required to follow these decal guidelines. To be eligible for the Toyo Tires Contingency Program you must properly display decals on your vehicle as shown and register ONCE PER YEAR for the program. TOYO TIRES CONTINGENCY PROGRAM - SPEC TIRE YEARLY REGISTRATION FORM Changes for 2021: No Changes. Decal Placement is the same as the 2020 Season. Additional Information: Toyo Decals may be custom made as long as the correct design and minimum size requirements are being used. Toyo Tires decal file - https://drive.google.com/open?id=1DL4gmXgTJzp0WQB4Czi0669VzXvUeWuG The Toyo Tires Logo must be the same size as the ones provided at the track. The size should be approx 17" wide x 2" Tall. Toyo Decals may be created in any color as long as it is a contrasting color from the car. (Example - White Toyo Decal on Black Car) Cars with the same color Toyo Decal as the car will have their registration rejected until corrected If your car is not listed, use the car that is closest to your make/model as a reference IMPORTANT!!! Proper placements of Toyo Decals will be strictly enforced for ALL NASA Competitors and vehicles. Competitors not in compliance will result in a delay or denial of your claim! Edited January 4 by Aldrin V. Quote Link to post Share on other sites
