Randy Flores 0 Posted January 19 Share Posted January 19 2002 Mazda Miata / Spec Miata / Currently set up for track fun and Enduro Racing. 23' Enclosed Trailer Entire Package $25,000.00 TURN THE KEY! ARRIVE AND DRIVE! Built Motor - Head and Block are decked to Mazda minimums, Oversized pistons, Intake manifold is ported and matched to the head. Intake Cold start butterfly's have been removed, Custom Valve seating, This motor would not pass Spec Miata inspection. Motor Built by DC Racing Engines Denver. This motor has about 8 hours of track time but only 6 hours in this car and this car has never been raced. Original running motor is also included. (SO 2 MOTOR PACKAGE) MBS Performance Exhaust - Spec Miata Exhaust (wrapped from header to muffler with exhaust heat wrap to reduce heat transfer to driver through tunnel). (Tunnel is also lined on the driver side with heat insulation) ACT Clutch on the built motor stock clutch on the original. 5 speed Transmission is original and has no issues FRESH Torsen differential (4.1:1 gears) (Spare Diff Housing) and original open diff included. ALL FLUIDS HAVE 4 TRACK HOURS all Redline racing products. (New spark plugs when fluids were changed) Fuel Filler neck - gas pump nozzle flange has been removed to allow for fast fill with fuel jugs. Power steering has been deleted, AC has been removed. 2 sets of Wheels, 15" Enkie and New set of 15" MOMOs Spec Miata offset 13lb wheels 4 hours on new set of Maxxis Victra VR1 tires. All 4 corner fenders have been rolled for tire clearance. Drivers floor under seat has been lowered 1"for more head room, the seat is on Sparco sliders. ALL THESE PARTS ARE INSTALLED New Rear Axles (and old ones for spares) New-3" Quick change Enduro Wheel Studs & Nuts New-MPI steering wheel and quick release New-Cut off switch / New Battery as well as a (Spare Battery) New-Mishimoto Radiator / Fans & Silicone Hoses New-Flyin Miata V-Maxx XXtreme adjustable coilovers (Track Package) (not legal for Spec Miata racing) New-Moss Miata end link swaybar heim join (all 4 corners) New-Flyin' Miata Big sway bars front and rear (might not be legal for spec miata racing) New- Polyurethane Differential mount bushings (not legal for spec Miata racing) New-Shifter rebuild kit New-Hawk brake pads New-Autometer Water Temp and Oil Pressure gauges New-Radiator fan switch New-OMP Halo seat 36" waste size / New MOMO Halo seat 34" waste size (passenger side seat brackets are mounted in car for this MOMO seat) Old-5 point SFI rated harness - dates are expired. Not installed New-Window net and hardware - New-Drivers wing window with open and close cooling vent 23' Enclosed Trailer - Double 5000lb Torsen Axles w/ brakes Custom fold down ramps Custom tiedowns Custom 8 tire / wheel storage 2-4 drawer Storage cabinets w/work bench top, shelf and locker for race suits. 2.5" hitch 2.5/16" ball and anti-sway bars included. Brakes, wheel bearings and tires have about 4000 miles on them. This is a very well maintained trailer! The exterior is rather unattractive but its a very solid unit! Serious inquires only! Quote Link to post Share on other sites
