The Cart Before the Horse: My Spec3 Build
Posted (edited)
Picked up another engine from a guy in DC. Decided I would NOT open it up unless it seemed completely needed since I was clearly messing up something along the way with the last engine. Pulled the current engine and found that the head gasket failed on the driver side of cylinder #5 for no apparent reason and that Cylinder #2 was low on compression as well from the bottom end. The radiator seemingly took a big lick when something flew off another car and broke out my grill going into Oak Tree, but I'm not sure that really affected cooling capacity.
 Installed my baffled oil pan, safety wired oil pump nut, new gasket, new o ring for the dip stick, valve cover gasket, rear main, and some other seals on the "new" engine and also found that my oil filter housing had a huge piece of plastic jamming the drain back valve open which answers my question about why the engine took so long to build oil pressure on startup. I also bought all new equipment for the cooling system (new CSF radiator, aluminum expansion tank, stewart water pump, hoses, thermostat, etc), Installed the engine and got everything bolted back up and started going through my wire harness to fix whatever caused the small fire I had. It seems one wire I cut actually had THREE ends, and thus was still connected even though I cut one end. It was the 12v charge signal from the alternator to the gauge cluster that controls the alternator light and also excited the alternator itself. I ran a new wire for that and double checked everything else. I think I should be fine to run one more race before I send my harness off to a pro to get thinned.
Edited by TaylorGoesFast
  • 4 weeks later...
Well... it happened AGAIN.
Junk yard motor was amazing until it wasn't. Battled some issues with the cooling system to start the day, but got it sorted and ran a new Personal Best by 2 full seconds (consistently) and qualified 5th out of 15 drivers for the Friday race. My mirror fell off during the race, but I ended up in 4th place with the 3rd place guy in my sights and running similar times, then with 2 or 3 laps left... I dropped a valve.
Lesson learned? Replace valve retainers on these cars before anything else. I've got some horrible luck (no one else has seen a failure rate like I have), but also that's on me for slapping a junkyard motor in all willy-nilly like that.
I picked up a built head from a fellow racer, but the head is undocumented, meaning I don't know for sure what was done except valve seals, and 14 new valves. I'm 80% certain the valve retainers were replaced, but I'm not sure I want to chance it. Depending on when parts get here, I may try to have everything back together for an even I'm instructing at next Thursday. Fingers crossed.
  • 5 months later...
Posted (edited)
Long time update coming. I managed to order the last valve spring retainers from Bimmerworld and got them to the machine shop to install on the head I bought. I pulled some long hours in the garage and got the new head on the engine days before the November Summit event. When replacing the head I found that the junkyard block was not in great shape. Heavy pitting on the deck surface and a chip was knocked out of the cylinder edge from the valve hitting the piston and knocking the cylinder wall. I knew the block would need to be reworked or replaced, but I needed to get it back out there and there was no time for anything else.
Summit went well and the car felt decent, but a bit down on power. I asked a fellow Spec3 racer to take my car out himself to see how it felt because I was concerned how I wasn't able to even get close to 5th gear on the front straight. He said it felt fine (but this may have been a red herring seeing as he ended up finding his motor was bad too). I keep pushing, thinking I was just not driving well or something. I was also struggling MAJORLY with oil leaks. Crazy valve cover oil leaks that I could not get to stop. I think that distracted me from the from the real problem soon to rear its head.
I was rounding T10 and lost all power and starting SPEWING oil smoke out the exhaust. I dove in to the paddock at Pit-Out and limped back to my paddock spot. The engine was done. I packed up early and headed home. Thinking this was somehow my fault and that I had failed at the head gasket job, I decided to throw in the towel and have someone else work on my car for once. I contacted one shop and planned to drop my car off in January. This shop also happened to have an M50 they could sell me, so I paid them for that with the plan to swap it in when my car got there. However, this shop ended up having some family medical issues that did not allow them to work on my car so I ended up taking my car to GTPeace well behind schedule if I wanted to make March VIR.
I dropped the car and new engine off at GTPeace with a huge box of parts from FCP Euro and waited. It wasn't long before I got a call to explain that one of my pistons had melted. Yes, piston #1 melted. Seemingly from an injector failure or something else. This caused major blow by, which caused the pressurized crank case and crazy leaks from the valve cover. So I expected the block to be toast, so no worries there, but then comes the concern of the built head I had just purchased and installed.
Well, the bad news is that head is cracked. So there's no way I'm making March VIR and the machine shop will be swapping everything from the built head over to the other head from the new engine I bought, and hopefully I'll be ready for April at Summit Point.
https://imgur.com/ugUsjSn.jpg
https://imgur.com/M9IsxFs.jpg
  • TaylorGoesFast changed the title to The Cart Before the Horse: My Spec3 Build
Finally a good update!
I got the car back just in time for my move to Pittsburgh. I barely touched the car until a few days before the April Summit event, but I did get a chance to install new calipers, guides, rotors, pads, and also some bimmerworld strut spacers to give me some much needed camber to the front wheels. I also installed a fire system and a center net so I can run with BMW CCA if I want.
My focus on the first day was just finishing a race, so I didn't really push hard. Still managed a 4th place finish though. The car was much more planted and had much better turn in with the added camber. The engine felt great and it's really nice having an engine that actually works for once. This may be the first time I haven't been down on power. The bad news is, the car is 100lbs over the minimum weight with not much left to remove from the car. So it's time for me to lose some weight and to also finally do a real wire harness thinning. I ordered a lightweight battery to shave 20lbs off before the next event.
For the sunday race, I'll just share the race recap from NASA SpeedNews.
Summit Point Motorsports Park - Summit Point, West Virginia. A scenic facility an hour outside Washington, D.C. and the location of the second event of the NASA Mid Atlantic race season. An Easter Weekend event meant racing was on Friday and Saturday and a much less crowded Paddock than the region is used to seeing. Even with those circumstances, NASA Spec3 fielded one of the larger classes and even had their second rookie of the 2022 season complete their competition evaluation and join their ranks.
Friday
Friday saw Sean O’Hara take pole with a blistering 1:24.838 lap time, followed by Jon McAvoy, Joey Thomas, Taylor Johnson, and Edward Higginbothom. Edward being one of the latest racers to join the class in 2022. The race that evening started with a typical standing start with McAvoy and O’Hara battling for 1st going into turn 1 and Thomas and Johnson battling for third. Over the next 30 minutes these two games of cat and mouse played out as expected until a new variable was thrown into the mix. A Spec Miata dropped oil in the famous “carousel” portion of the track which consists of a high speed drop during a right hander dubbed “the chute” followed by a hairpin left and a long sweeping right. This tricky part of the track requires careful throttle modulation, left foot braking, and a lot of nerve.
The oil caused the race pace to change considerably and the Spec3 leader became its first victim. As the remaining laps counted down, O’Hara maintained his lead but had significant pressure in his rear view, and a loss of traction in turn 5 due to the oil slick caused enough understeer to send him through the grass. McAvoy took advantage and claimed the lead position but his success was short lived as the rear of his car stepped out aggressively in turn 7 near where the Spec Miata had pulled off track after their spill and the Spec3 national series leader spun off track toward the tire wall. Luckily, speeds at this part of the track are at their lowest and McAvoy was able to slow to a stop and rejoin the race, now a distant second place again.
Meanwhile, the battle for third had been won by Joey Thomas, who enjoyed a lead of over a second on the fourth place Taylor Johnson. Now, however, Thomas was within striking distance of McAvoy for second place after his spin. The two spent the remaining laps jostling for silver position while Johnson used the battle to his advantage to gain ground. Ultimately, the remaining laps dwindled to 0 and the finishing order was O’Hara, McAvoy, Thomas, Johnson, Higginbothom.
Saturday
Saturday Morning saw the qualifying race, the “Beast of the East” which allotted extra season points for the winners of classes within the field grouped by their best time from the race the previous day. Group #1 saw the 5 fastest of the lightning racers, McAvoy, O’Hara, and the front runners of the Honda Challenge class. Group #2 saw the next 5 fastest and this included Thomas, Johnson, and the lightning fast Jason Crisgavage in his Spec E30. 3 more groups of racers followed behind as well.
The qualifying race churned on with not much out of the ordinary until the racers encountered a red flag as the result of the newest Spec3 racer in the field going off in T1 and rolling the car onto its side. The driver, Edward HigginBothom was unscathed, however, during the incident, the windshield was damaged and an engine mount was broken. This marked the end of the qualifying race with Jon McAvoy taking the overall winner position as well as winning his group.
Saturday Race:
The race grid for the Saturday Lightning race saw Sean O’Hara once again on pole, followed by McAvoy, Thomas, Johnson, Thomas Norton (who had just completed their competition evaluation the day before), and Edward Higginbothom, who was racing with no windshield and only one mirror after kicking the windshield out and replacing a broken motor mount to get his car back on track after his rollover.
The battles for 1st and 3rd that took place Friday were back, and back with a vengeance. McAvoy and O’Hara spent the first several laps basically door to door while Johnson and Thomas traded third place back and forth. Each lap, Johnson orchestrated a run through the final turn that allowed for a pass crossing the start/finish line heading into turn 1, where time after time, Thomas would out-maneuver Johnson and the two would head into the high speed, blind, off camber turn 3 side by side. Down into the chute, Johnson was able to out brake Thomas and make up lost ground to follow nose to tail through the carousel and the whole dance would play out again, lap after lap. Johnson attempted turn 1 on the inside and outside of Thomas and could not make the pass stick either way.
This battle raged on until the closing laps where Johnson plotted to set up a pass to steal the final podium position. McAvoy had already managed to snatch first place from O’Hara with a pass between turns 1 and 3 laps prior. The racers received the white flag signifying the final lap and the Spec3 racers knew the time was now to execute their plans. However, Johnson’s fuel gauge had long since bottomed out on “E” and his fuel level was dangerously low. As the third and fourth place racers rounded the final turns of the track, Johnson’s car began to sputter as the fuel pumps struggled to find what remaining fuel there was. Johnson could finish the race, but there was no way a pass could be made unless something dramatic happened.
Then something dramatic happened. The front running Spec Miatas had collected each other right before the checkered flag and this caused a waving yellow in the final turn of the race. No passing allowed and the racers were forced to slow as they crossed the line. All of the racers escaped without injury and the Spec3 results showed McAvoy, O’Hara, Thomas, Johnson, Norton, Higginbothom.
https://www.youtube.com/watch?v=kOCPGTjEkRg&ab_channel=TaylorJohnson
Spec3 Forum: [url]https://community.drivenasa.com/topic/58632-spec3-constructors-guide/[/url]
Official Website: [url]https://drivenasa.com/road-racing/spec3/[/url]
Facebook Media Page: [url]https://www.facebook.com/NASASpec3[/url]
Instagram: [url]https://www.instagram.com/nasaspec3/[/url]
Facebook Discussion Group: [url]https://www.facebook.com/groups/spec3[/url]
  • 2 weeks later...
Good update followed by not so good!
We had a few Spec3 racers head up to Watkins Glen to run NASA Northeast so I checked that track off the bucket list. I signed up for three days because all the sim time in the world can't prepare you for a track you've never been to! Friday went well for the first hour and a half of track time and I got down to a 1:28 or so which was faster than any Spec E30s, and that's always my minimum goal. In the 4th session I lost coolant and the car "overheated" (read, temp gauge went up) . Long story short, I chased that issue non stop for the next two days and never got it resolved. 10-15 minutes on track with perfect temps, then when it'd get near 180F, it'd pop the expansion tank and I'd lose coolant and have to get towed in.
The good news is that the Spec3 track record at WGI is now a 2.13 which was the fastest of anyone in the lightning class!
You may remember that I stated previously that I finally caved and took the car to a shop to have the last head/engine swap done, so the car went right back to that shop and they tore into it to find the head gasket blew out between cylinder 6 and the big water passage back there. This is the thinnest part of the headgasket. Why this happened, none of us have a clue. The simple answer is "an air bubble" but the car was perfectly fine for an entire weekend before on the fresh head gasket job. Perhaps the engine never got hot enough to surface the issue at Summit Point. I'm not sure.
The car should hopefully be ready for Hyperfest and this will be my second time ever having sticker tires, so I'm really pumped for that. We should have a good Spec3 field ready for our Spec E30 vs Spec3 vs Spec E46 battle royale sponsored by Bimmerworld and then hopefully I'm off to Road Atlanta with some others to welcome our FIRST NASA SOUTHEAST SPEC3 RACERS!!!!!!
Spec3 continues to grow! If you know anyone interested in joining the series as a racer/sponsor/partner, please reach out!
  • 4 weeks later...
Posted (edited)
Not good update followed by great update!
GTPeace was really suspecting that I had a lean fuel condition again that lead to cylinder 6 getting hot, so we threw the kitchen sink at it and some other goodies.
New fuel pump, filter, pressure regulator, and injectors.
Euro coolant tank with the proper NLA euro hardline
2 new tires
Alignment
GT Peace also did the R&R on the head gasket for free, which was really cool.
They also patched up my body damage from WGI.
Lastly I got an AFR wideband installed so I could monitor my fuel mix on track and see if it was running lean.
I picked up the car on Thursday on my way down to Hyperfest and had to install new brake pads when I got there. I used this time to also remove my rotor dust shields for improved cooling. The car ran really well all weekend, albeit hotter than it used to, but I suspect that was from the warmer thermostat and how poorly my front ducting/aero fits now after the crunch. The car noticeably had more top-end pep so I'm starting to suspect it really was fuel starved up high. The car was great Friday and Saturday and I turned times near my PB even with my timidness and warm temperatures.
I finished third on Friday and 4th on Saturday in a field of 8 Spec3s (amazing to say that 8 is a really small field for us these days!)
Then on Sunday I took my car over to the dyno and it dumped out all of the oil. In all of the haste as of late, the oil filter housing that got put back on my car was the super old style from an E34 engine that used an o ring, a plug, and a circlip to plug the casting holes on the back. Luckily I had a spare newer-style one in the trailer so I swapped that, but I missed qualifying so I had to start the race at the back. I got by everyone up 5th place and things got crazy. The leader got punted and had to retire, the then new leader got DQ'd, and then the third place (now leader) racer put their car in the wall, so I was in second place. However, the checkered flag flew for the car behind me (not me) and I thought it was for me so I pitted early like an idiot. Ended up with third place. I'm bummed because if I had made qualifying, I could have easily snagged my first win here, but those are lessons learned for next time!
https://www.youtube.com/watch?v=aycdKtzNWOA
Also, the start of the Bimmerworld race was really crazy due to some SpecE46 guys being... rambunctious.
https://www.youtube.com/watch?v=VX2CBrrnyu8
  • 1 month later...
Posted (edited)
TL;DR: Great weekend. Two third place finishes. Absolutely amazing racing the whole time and the Sunday race video is a must watch for some insane racing. Sunday link at the bottom.
Full summary:
Great weekend for me! The car feels dialed in, predictable, and reliable so I'm just focusing on driving. Did nothing to the car except put gas in it all weekend!
Saturday I qualified third, but Jake got by me with a great start, so I had to battle to get by him and try to chase down Joey to try to snag P2. Joey and I traded lap times back and forth all weekend so it was really tough to catch him from so far back but lapped traffic held him and Jon up enough to keep me in the chase. Finished P3 right behind Joey and Jon for my first Saturday Podium (I think this is Podium #3 for me?)
Probably the least interesting video, but still good: https://www.youtube.com/watch?v=FgbKLelYRYg&ab_channel=TaylorJohnson
Sunday in the Beast of the East Qualifying Race, Jon, Joey, Me, and 3 Honda Challenge folks were in the "White group" and battling each other. Joey ran away from me while I battled with Brian Maeng and Jack Cobetto and Jake Thiewes terrorized me in my mirrors, but eventually I got past Brian (or maybe he let me past so I wouldn't collect him with a missed braking zone) and I kept pushing but didn't have enough time to turn a good clean lap I was happy with. Qualified 4th for the race.
Exciting BOTE with lots of close racing with HC and Spec3:
https://www.youtube.com/watch?v=_uDqCd9hU7M&t=4s&ab_channel=TaylorJohnson
Sunday is when it got really tasty. I was behind Jake and we had a great battle. Joey started P1 and we had a great quartet of Spec3s zipping around the track for quite a while. I was able to box out Jake by using a slow out of class car as a roadblock and then I set my eyes on catching Joey for P2. I ended up catching him with quite a bit of time left in the race and I ALMOST made a pass stick in T1 but I still haven't honed my race craft enough to get passed the great Joey Thomas. Jon, Joey, and I finish the race out weaving throughout traffic while chasing each other for a very close 1-2-3 finish with me splitting two out of class cars to go three wide across the line. I turned a faster lap than Joey with a 1:27.213 so I have hopes I can best him one of these days!
This is the video to watch:
https://www.youtube.com/watch?v=YMkaVQIyb3c
  • 1 month later...
Posted (edited)
Another great event!
July was a crossover NASA Great Lakes and NASA Mid Atlantic event at my now "home town" track of Pittsburgh International Raceplex. It's a 50 minute tow from my house so I strolled up Thursday night to hang out and relax with my now establish camping setup of enclosed trailer, nice little cot, TV mounted on the wall, coffee maker at the ready, and some nice camping chairs and a big canopy. I'm trying to save money so I didn't sign up for test and tune and instead was hoping to rely on a few hours in Assetto Corsa on a Pitt Race mod track. The weather was decent and all was well until a fellow racer finally fell victim to the rattly transmission he had been ignoring for a year (I blame his fancy chassis mount shifter). We rounded up a transmission to get transported from Richmond, VA to Pitt Race and it arrived after 9PM. We got it installed by 12:30 at which point I left him to his own devices to wrap up and he was in bed by 1:30 AM after tidying it up.
Warm and Qualifying saw me running a 2:09 while the pole sitter ran a 2:03. This put me in 6th out of 8 on grid for the race, qualifying a few tenths out of 4th. I was really disappointed in myself since I ran a 2:07 last year with a tired motor and knew I should have been faster. I adjusted tire pressures and got my head right for the race where I jumped to 3rd on the standing start and was fighting for 2nd until halfway through the race when the series leader (who spun on the start) came rocketing through and passed us both to grab 2nd. I finished 4th while running low 2:06s on a hot day, which I was pleased with.
Sunday saw more of the same with me qualifying 4th and battling for third the entire race, even passing Joey Thomas for third a few times and then giving it right back. We both ran very low 2:06s and almost broke 2:05. We ran within ONE THOUSANDTH of a second of each other for our best lap. Truly a great battle.
Now on to VIR and NJMP in back to back weekends in August where I hope to work on smoothness on input to upset the car less and hopefully get some new personal bests. I only need a few tenths to start snagging third place consistently.
https://www.youtube.com/watch?v=t9ppl0C_52Q&t=84s&ab_channel=TaylorJohnson
https://www.youtube.com/watch?v=8m0UsuxFjis&t=11s&ab_channel=TaylorJohnson
https://imgur.com/weEfEEv.jpg
  • 3 weeks later...
Posted (edited)
August VIR! Good and relatively uneventful weekend. My previous best was a 2:16 something at VIR and I got it down to a 2:14.7 over the weekend. We had 8 racers and I qualified and finished 4th both days with some battling with Joey Thomas. Power Steering line failed Saturday morning and I knew it was bad, so that's my fault for not replacing it sooner. Patched it up and it help together fine. On to NJMP with NASA NE this weekend!
https://www.youtube.com/watch?v=IeANpBvRmyk
https://www.youtube.com/watch?v=hLFtQ6vbUIY
https://imgur.com/kPyi8Ii.png
NASA Northeast! NJMP!
Thunderbolt is amazing. Such a fun and unique track and the facilities are superb. I wasn't expecting everything to be as nice as it is, but everything was top notch. The timing tower view is crazy cool, the officer's club is nice, and that's the best pro shop I've ever seen. So many garages and villas and power poles at every paddock spot! The course itself is very tricky but also very rewarding when you get it right. Hard braking into T1 with a near flat footed run through T2-T4 is really neat, then a very slow turn 5 with a high speed turn at 6 with a lot of run off begs you to push it harder and harder... then the octopus! Such a cool turn. So low speed and so long! Fighting for grip the whole time and if you get it right, it gives you a chance for a run down the front stretch to pass.
That said, I had never been here before, so it was a lot to learn quickly. The other folks did test and tune Friday and warm up Saturday was my first shot at the track. I ran a 1:37 to start, which is 4 seconds off the SE30 track record of 1:34 something, which was my goal all weekend. I got down to a 1:36 in the race Saturday and snagged my first win!
Sunday was very interesting. Northeast does a qualifying race with a rolling start, and I started in the wrong gear. Ed pulled past me and I followed him with the plan to keep just enough pressure to make him make a mistake and capitalize. I snuck by him a few laps in and then focused on pushing my lap times down. I was dropping a few tenths every lap until I ran a couple 1:35s and then pushed off track and through the grass. I checked my mirrors and realized no one was around me anymore so I backed it down by a lot and cruised to the finish. The whole weekend, I had been nursing 4 completely bald tires, crossing my fingers they wouldn't cord in the race, and I certainly didn't want to burn them in a qual race. I'm very confident a 1:34 or 1:33 was in the works with a little more time and some tires that had rubber.
Then the torrential rain came. It rained for at least two hours and completely flooded the place. Water flowing through the paddock and the track was under water. The race approached and the sun came out, causing us all to debate whether rain tires were the move. We all opted for the drys and went to grid. When we went out on track, there was standing water everywhere so we all were crawling around the track just trying to keep the cars pointing forward. Edward got passed me on the start (again I was in third gear when I should have been in second for the rolling start) but then he pushed wide in T1 and I passed. We fought back and forth for the whole race as the track dried but I had mentally decided this was not the race to push the car or bin it in a wall, so when I saw Ed go for a late pass on the inside into the Octopus, I gave him a wide berth and decided it was best to live to fight another day. Plus, it'd be fun to try to get around him again. I bided my time waiting for the white flag for one final push and I got a run on him coming down the front straight on the last lap to go across the finish line door to door. Official timing shows me one tenth of a second behind at the finish.
Overall, a very fun weekend at a great track. Hoping to get a field for Watkins Glen in October.
https://www.youtube.com/watch?v=TWErfvzh4SM
  • 1 month later...
October VIR 2022 and Mid Atlantic Season Finale. Personal Best 2:14.138 so close to 2:13!
https://www.youtube.com/watch?v=ckC4_bHPcXA
I came into the weekend in 4th place for the season championship. I snagged a P2 finish in the first race Saturday and a P3 in the second race to close the season. This brought me within a race's points of 3rd and 2nd for the season. So many things I could have done to make up those points during the season!
On to NJMP next weekend for the closing of the Northeast season and then Road Atlanta in September for my first Southeast event!
  • 2 weeks later...
The busy year stays busy! Final event of the NASA Northeast season. Unfortunately we only had two Spec3s (we are a full year ahead of when I expected to have a NE field!). This was my first time at NJMP Lightning so I did the test and tune on Friday to get my bearings. I was aiming to beat the SpecE30 track record (That was set a lot time ago on much better pavement!) and I managed to do that in my second session out Friday with a 2:17.8. However, our track records only count if they are in a race. I was trying to run down this time all weekend and was never able to consistently run sub 2:18 after that. I was still faster than any other class in Lightning except some of Honda Challenge, so I knew I was doing alright.
During the race, we started mixed with SpecE30 based on time since both classes were light on entries, so I started on pole. We had a rolling start (Also because so few racers on track total) and I pulled away when the green flag dropped and never looked back. I didn't have my rear facing camera on, but you can just imagine I was just by myself the whole time. Basically a TT session.
Car is still running strong. I unloaded the trailer and dropped it off at a trailer shop for some maintenance. I'll be working on the car a bit to clean it up before heading to Road Atlanta the first weekend of December.
Fast lap: https://www.youtube.com/watch?v=X4xolslN7IE
Race: https://www.youtube.com/watch?v=cEGyrNVtMK8&ab_channel=TaylorJohnson
[img]https://imgur.com/XMxvq29.jpg[/img]
  • 4 months later...
Posted (edited)
The long slumber ends!
My offseason "To do" list was big. I didn't do all of it :D This was my first off season that didn't require any engine shenanigans so I took time to enjoy life, traveled a bit, picked up guitar, etc. Now it's back to the grind.
First thing was a new windshield. I've been rocking the 30 year old glass forever and it was pitted and cracked all over. Happy to finally be able to see again.
I noticed my window net had expired (I've been racing that long?) so I installed a new one and changed it from the balljoint and rod style to the "wrap around the door bar" style, so hopefully that'll make egress better. My suite would always catch on the lower bar.
My front bumper has been saggy since my meeting with a tire wall during comp school and I attribute it to bent bumper shocks or maybe a slightly tweaked frame rail. I tried to bend it back with a jack and piece of wood and ultimately settled on just drilling new holes in the bumper core bar for the bumper skin to sit higher and moving on. I also replaced the screw in tow hook with a strap style wrapped around the bumper shock.
https://imgur.com/0u5R5M5.png
Fresh engine oil, diff oil, and transmission oil. Everything was fine except the transmission which had a LOT of metal in it, but no chunks. It shifts fine and doesn't pop out of gear, so I'll just start changing fluid twice a season or maybe three times considering how often I race, and monitoring from there. These transmissions are cheap (yay Spec3) so I always have a spare with me in the bed of the truck and it's an easy swap regardless.
https://imgur.com/ziUF2Lc.png
New pads and rotors along with a fresh brake bleed has the pedal feeling very nice as well.
I then set in to nut and bolt everything and I stepped up my game from a silver sharpie to a "torque paint pen". I found my rear subframe, engine mounts, and transmission mounts were all loose even though my sharpie markings indicated no movement of the bolts. Perhaps the bushings shrunk or were squished? At any rate, the clunking in the driveline is completely gone. I'm embarrassed I didn't fix this sooner. I also found my rear sway bar had completely popped out of the bracket. I wonder how long I was running like that?
My car has been leak free for a while, but developed a small drip from the power steering rack. I've been religiously checking the hoses, thinking that was my problem, but I think I finally tracked it down to the pinion seal on the rack itself. Not a huge deal for now, but I'm looking to source a new rack to have on hand for when the time comes. It seems rack doctor is no more, so a reman unit should be just fine.
https://imgur.com/dPa1ZVv.png
Lastly, I found a shop by my house that I can just take service roads to with zero traffic so I popped by there for an alignment (first in like a year) and found that I have way more front camber than I expected. Good for me I guess?
March VIR in a week and then a busy year of 13 race weekends planned between Northeast and Mid Atlantic! Let's do it!
https://imgur.com/UICGSAG.png
https://imgur.com/iszEbpr.png
  • 1 month later...
Three race weekends flew by!
VIR is a blur, but my goal was a podium and a new PB (previous best being 2:14.1 set in October). Long story short, I matched my PB a bunch of times but I'm still not pleased with my performance. I'm a good 2 seconds off the front 3 guys and I want to be faster. The car is still over weight with me in it by 50 lbs at best with an empty tank, so I need to lose weight personally. I finished 4th and 3rd or something like that after a crash out and some contact by other folks in the field.
I had a grinding noise all weekend that I thought was my rear brakes. It was not. More on that later.
Replaced the rear pads because they had some really weird wear and I thought they were making a noise. Threw a new steering rack in the car to stop the leaks, and headed to Summit Point. Saturday warm up was fine, but the noise was still there. I checked the wheel bearings and everything felt tight. I let someone do parade laps at lunch in the car and it came back with a very wobbly rear wheel which ended my weekend.
I got the car home sunday night and immediately set to work on disassembling the rear bearings as I only had 3 days before I had to leave for WGI. The rear driver wheel bearing was completely destroyed and came out in pieces. The balls went everywhere and the race/cage was destroyed. It was so bad that the axle ground itself down on the trailing arm and wore away some of the wheel speed sensor. I got the parts in Wednesday and worked all night to get it together. Had to source some wheel speed sensors locally after I damaged one pulling the bearing out. I got it all together and headed to WGI.
Friday was a test and tune and I helped one of my new Northeast Spec3 rookies work out the kinks in a car new to him. I jumped in his car to set some laps as a baseline to prove to him what was possible and gave him something to work towards. The track record for Spec3 is a 2:13 set by Charles Ford, so that is always my goal. After my first session, I came back in to find one of my tires completed delaminated or had a belt separate as it was swollen and bulging on one side. That's my fault for running tires from 2016. I swapped it out for some equally hard and crappy, but newer 2019 tires and kept working my times down. I got down to the low 2:17s before calling it an early day and visiting from distilleries with Rachel, Lemon the dog, and Rachel's friends.
Saturday warm up was good and I turned a 2:16, and then in qualifying I turned a lower 2:16, all with bald left side tires with a million heat cycles. Then the rain came in and the lightning caused the track to be shut down long enough for them to cancel the races for the day. Sunday would be a double points race day. I swapped my tires side to side so I could have the two tires with life on them on the outside for most turns. We started the race and I quickly passed the ST6 cars ahead and worked my way through some of the Spec E46s as I came through turn 9 to see a car parked right on the racing line facing me (the yellow flag didn't come out in time for me to see it before turn in) and I just barely avoided balling up both of our cars. I then set out to churn some more laps and got down into the 2:15s to tie my personal best. I took the win in my class of 2.
The second race was postponed due to weather again and then the track was standing water. I love a rain race, but the rookie didn't bring rain tires, so he couldn't go out. 1 car doesn't make a class, and going into a race with no one to race against is poor sportsmanship as you're just someone in the way at that point. I packed up early and waiting for the race to end to make sure the SE46s had a clean race and I didn't need to DQ anyone. Then I headed home.
Next up is Hyperfest at VIR in mid May followed up NASA NE at NJMP with another Spec3 rookie (or 2!) doing comp school and running their first races with us the first weekend of June.
To do list before then:
New wheel bearings up front
New brake pads up front
Mount new tires and rotate the old
New brake calipers on the rear
https://www.youtube.com/watch?v=qWRTb9xVlLs
  • 2 months later...
Hyperfest was great as always, but my race weekend was a bit disappointing personally. Before the event I installed new rear calipers, new brake pads all around, new wheel bearings up front and replaced my 15 year old shock absorbers (I bought them used). I finished 4th in the Saturday race and was chasing my PB but noticed a weird vibration up front in right hand turns. This later turned out to be both of my front shock absorbers either unthreading at the top or coming loose at the bottom. I would not figure this out until well after the event. One of my competitor's had their car taken out in practice by a honda challenge in T1 so that put me in solid podium contention for Sunday. We had two races Sunday and I finished third in both but was still super frustrated at how I seemingly had forgotten how to drive the car well. Now looking back, I don't feel bad because both of my front shocks weren't even connected. I also managed to bend FIVE of my wheels. It seems a divot at the exit of Oak Tree which had never given me trouble before decided to sink a little before this weekend and start destroying my wheels. I wasn't going off track so I could never figure out which spot on track was doing it until it was too late.
NJMP
I didn't discover my front shock issue until I was loading my car for NJMP mere hours before I needed to be there. I scrambled remedy the driver side shock which had literally come apart and unthreaded itself into two pieces. I ended up rolling into NJMP right before the gates closed with one of my 15 year old shocks reinstalled on the driver side, unaware that the same thing was slowly happening to the passenger side too. After the Saturday race I noticed my car was very bouncy and found that the passenger side shock absorber had also started to come apart. I hastily threaded it back in and secured it with loctite before the sun went down, but having lost move of its oil, I wonder how functional it is now.
I was able to get a win at NJMP both days and set a new Spec3 record by over a second a half (previous record by me the only other time Spec3 has ever been at NJMP) with a 1:34.4.
On to Lime Rock next weekend. First ever Lime Rock field for Spec3!
  • 1 month later...
Wow! So much racing. So little time. 2 more events have passed since my last post.
Lime Rock was absolutely amazing. The surrounding area is beautiful, the track is so fun an historic. It is truly an experience just to be there, let alone drive the track. We had a great field of 4 Northeast Spec3s, 1 Mid Atlantic Spec3, and a Spec E30 that was all alone so I let them race as a Spec3 for the weekend after everyone agreed that if they get beat by a Spec E30, they'd live with it.
We all picked up the track really quickly considering most of us had never been there, and NONE of us had ever been there in a Spec3. Nor was there any Spec3 lap record for reference or footage of a Spec3 driving the track. Long story short, Alex Rubenstein and I battled back and forth with me wining the Friday race, him winning the Saturday Qualifying race, and me winning the Saturday Feature race. My goal was to run a 1:02 something and beat the Spec E30, but it's such a short track that it becomes really hard to shave time off once you are that low. I ran a 1:03.229 and set the first Spec3 lap record with that. If the weather is cooler next year, there's no doubt one of us will break that and run a 1:02 or maybe even a 1:01 some day.
The races were a lot of fun and the Saturday race was especially exciting because Alex and I were moved to the back of the field by accident during a double yellow with an erroneous black flag so we had to fight through the entire field just to get back to 1st and 2nd in our class.
Pitt Race was 2 weeks later and serves as a preamble to the National Championship race that will be there in September. We had 10 or 11 cars signed up, but unfortunately one racer found a tire wall during the friday test sessions so we were down a racer for the weekend. My last outing at Pitt Race in 2022 was disappointing as I was very sloppy and my inputs were very erratic. It was a tiring weekend and I didn't go as fast as I wanted. My personal best was a 2:06 something. I've done a lot of driving since last year, a lot of reading and studying, and a lot of practicing in iRacing, so my goal was at least to run a 2:05 if not faster. Saturday morning came and I ran a 2:08 in warm up which was not good. I didn't know it, but the warm up time set the qualifying grid, so I was stuck with some Spec E30s which was going to make qualifying with a good time for Spec3 hard unless I could get by them quickly. Traffic thinned out and I slipped by and ran a 2:06 or 2:05 which was good enough for P4 out of 9 for the race grid. We started the race under the same green flag as Honda Challenge and that was my downfall. The traffic jam in T1 found me dropping back to 8th place right on the start. I managed to battle back and pass several people to regain 4th and that's where I finished with a new PB of 2:05.3 in the race.
Sunday qual came around and I ran another 2:05 which put me right in the mix with the podium guys. The race started and the same thing in T1 happened again but I didn't fall as far back this time. Joey Thomas got the slip on me and ended up in second place for a bit until I was able to chase him down and pass him after he dropped back to 4th. Then I started to reel in P3 and P2 Jon McAvoy and Sean O'hara as they battled and was able to pass Jon when he went off in T1 during an attempted pass. I was able to hold onto third and chase Sean until the end of the race. That ended my weekend with a podium in a field that represented most of the fasted people that will be at the National Championship. Very exciting.
The car is in the trailer now and I plan to tow it to NJMP for the joint NE and MA event in a couple of weeks. The car needs nothing but I'll do a quick nut and bolt check and some new brake pads before then.
  • 5 weeks later...
New Jersey Motorsports Park! I think this article will say it all https://nasaspeed.news/race-coverage/around-the-regions/spec3-drivers-battle-one-last-time-on-the-old-pavement-at-new-jersey-motorsports-park/
Great time at NJMP. I found the air filter was completely clogged with grass and dirt, like completely. If that wasn't taking away 5hp, I'd be surprised. I threw away a solid P2 opportunity and chance to win on Saturday by going off in lap 1 (likely due to my shock coming apart, which was also likely due to a hasty trackside repair at did in June and never took back out to make sure it was done right). Finished 4th both days.
Car is all back together and ready for an alignment for nationals next week.
  • 2 months later...
Okay, it's been a while. Buckle up.
The NASA Championships were at Pitt Race this year, which is convenient seeing as I just moved to Pittsburgh last year. I've been picking up speed in Spec3 since comp school in 2021 and it seemed like this was a year that I could really hold my own and fight for a podium. Over the course of the event, I improved on my personal best by well over a second and had figured out where to pick up more time. In the qualifying race, I snagged P4 and ran within a couple tenths of P3 and P2. The championship race came up and we had to do an aborted start due to a huge SE46 pile up in T1 on lap one so we sat on grid for about 30 minutes and then did out pace lap again. This time, as I rolled to a stop, something didn't feel right. As the starting lights ticked down, I tried to move the shifter and it came completely loose. I signaled to my competitors that could see that something was up and the green flag dropped and everyone swarmed around me. I pulled my hands in and hoped no one would smash into me. Luckily, the car was stuck in first gear so I limped it off track and watched as the ~40 minute race unfolded without me in it. I was devestated. I got back to my paddock spot and found that the locking pin that holds the shift carrier onto the transmission came off. Ironic, because this pin is infamously difficult to remove, but mine was worn and loose from all of the times It's been removed over 30 years. I tossed a new pin in and was ready for Watkins Glen with NASA NE in a couple weeks after the event. My personal best from the event was 2:04.164
At Watkins Glen, I spent the weekend chasing my own personal bests and came away with 2 wins through some rainy weather that saw 3 Spec E30s totalled. I felt lucky that all of the Spec3s escaped without incident. My personal best was 2:15.310 which only beat out my previous best from last october drafting an ST5 car by a few hundredths.
The Mid Atlantic season wrapped up with an event at VIR in October where I had something to prove. Mathematically, I was unable to win third place in the region. Even with two wins, I'd be about 10 points back, so my goal was to finally crack a 2:13. A 2:13 in a Spec3 is elite category. There's only about 4, maybe 5 people in Spec3 currently that can run a 2:13 or faster and I've been running a 2:14.1 every event. I ran a stiffer rear bar setting and had some wider wheels than the last time I was there in May, as well as shocks that were not coming apart, or at least I thought that was the case. In race 1, the leaders got tangled up on a restart and I was in second place on the final lap when some goober in a rental GR86 ST5 car went off track, re-entered between me and P1 and then blocked me the entire way up the esses and drag raced me into "oak tree" instead of letting me go by and resume my race in my own class for the win. My transmission that has been giving me issues with the 4->3 downshift reared its head when I jumped a curb to go side by side with the GR86 and I missed the shift into third, causing me to lose all ground I had left on P3 behind me. Charles past me on the back straight and I settled for third place. In race 2, Joey beat me on the start again and that SAME GR86 missed grid and tried to pass me before the green flag flew to get to his field. The whole start was a mess and I ended up in 4th behind Joey. Him and I had an amazing battle and I eventually got by him and had clear track for the first time all weekend. My AIM showed me a mid 2:13 and I pushed hard. Going into Oak Tree, I found I had pushed TOO hard and I dipped two tires off and ended up in the wall. I limped off track and finished last.
For the last event of the year at NJMP, I banged out my fender and bumper and swapped in a new transmission just in time to make the event. Holy cow, I had not realized just how bad my old transmission was. I'm kicking myself for torturing myself and hurting my lap times for an entire year (10 race weekends+) with a transmission that was so difficult to shift. Being able to aggressively heel toe into third gear made me instantly fall in love with the car again and I'm still mad at myself thinking back to all of the times I gave up positions or ruined flyer laps because the transmission would co-operate. I managed to run a new personal best by over a full second and I reset the Spec3 track record at NJMP Lightning ( 1:17.066). I secured the lone race win for the weekend and finished the season as the Northeast Spec3 champion and Northeast Driver of the year.
Time to lick my wounds, replace some body panels, change the oil, and prepare for another year of Spec3 racing starting in March. In the meantime, I'll be cheering on my friends in Southeast as they have events every month until the MA season starts, all through the winter!
  • 3 months later...
New fender and nose panel installed. Pulled the front apron out with a shop crane. Got the fire bottle serviced and mounted transverse and pushed further back in the car. Also finally got my 190,000 diff rebuilt with new clutches and stuff. Spent a lot of time on iRacing this offseason, so I'm hoping to break into the 2:13 or even 2:12s at VIR this year!
Just need an alignment, swap some tires around, and do a nut and bolt check before I load off and make the tow down to VIR.
  • 1 month later...
March went well. Saturday morning practice, my ABS went out. Turns out that dropping your ABS module on the ground will probably break it. I found a module at Al Taylor's parts yard nearby and made it back just in time to qualify. I ran a PB 2:13.9 which I thought surely was good for 3rd or 4th, but now with all of the new talent joining Spec3, it was only good for 7th! Race 1 went well, race 2, I went off on a crazy restart and ended up dead last before the race ended early from some E30s putting each other in the wall. Race 3 was an insane battle with lots of passing. I'm a little bummed I didn't run 2:13 as consistently as I wanted to, but I have a plan to try to do this in May. The new rebuilt diff took some getting used to for sure.
April Summit saw another super tight field. I swapped on the new, stiffer H&R front anti roll bar that's been legal for a couple of years now and the car felt good.  Again I ran a new PB by a second a half ( 1:26.07) and fought tooth and nail for 3rd and 4th place. In race 3, I fought Charles for the win and lost by only 0.004 seconds after a 26 minute dog fight.
I put the car in the trailer after this event, and then rolled it right back out for the Watkins Glen race weekend a few days later. Car never skipped a beat.
Ended up running a new PB by over a second here as well, which was only a few tenths off the Spec3 record. Still lots to work on.
  • 1 month later...
No "build" updates to discuss. The car continues to chew through race weekends without issue. Up to about 70 races in a row without mechanical DNF or similar.
Broke into the mid 2:13 with a new PB of 2:13.2 at VIR with the help of the draft from Andy Schmidt and we have some awesome battles all weekend. Basically every second of every race was nose to tail. We actually ended up doing 5 races at Hyperfest with me winning 2 of them and finishing second in the other 3.
Then I headed to NJMP to try out the new pavement and ran a new PB by 2 full seconds. The car was favoring understeer with the new ARB up front and the additional toe in on the rear (.2 degrees) so I went back to zero toe after this event. I do fear that the new Spec3 front anti roll bar will limit the amount of oversteer I can dial in. We'll see. NJMP new PB 1:32.444
Shortly after that, I did some preventative maintenance and replaced the front control arms that have seen about 6 seasons of use over the past 4 years and then headed to Summit Point. The heat index was over 100 degrees both day and cockpit temperatures were over 135 degrees mid race for Race 1. The top 4 in Spec3 ran within a single tenth of each other basically all weekend and we raced basically two wide for 2 full hours.
  • 4 months later...
Wow! It's been a while! The car hasn't given me much trouble besides a wheel bearing and I haven't done much in the way of maintenance or really any mechanical work.
Since my last post:
- July Pitt Race was great. I did not run a new PB but still had some good racing. We all got to meet one of our newest Great Lakes Spec3 drivers, Clay who was in HPDE 3. Lots of great conversation with people in the region who were excited about the Spec3 growth there.
- August VIR was cancelled due to flooding for I went down to Roebling Road to do my first NASA southeast event with the new Spec3 people down there. It was a great time at a fun track and I managed to snag 2 podiums and a win in the last race.
- September UTAH NASA championships. I flew out to Utah to be the series leader for SE30 and SE46 for the NASA championships and had a great time. Racing in the championships in 2023 was fun, but being a part of making the whole event run was even more rewarding. 2025 will be at Ozarks and I'm excited to go.
- September Summit Point. We had some amazing racing and I duked it out with the reigning national champion in Spec3, Jon McAvoy and even came away with a win. I ran a new PB at the track only a little bit off the lap record.
- October Watkins Glen saw the biggest Spec3 field yet for WGI. We had a great time, although some other classes had oopsies in basically every race and it was all FCY. Really not much racing to speak about but it was great having so many new Spec3s racing at the Glen and that's hopefully a good sign for 2025.
- October VIR. Wow! I ran a new PB again, getting down to the low 2:12s and duking it out with Jon and Ross (who won MA Rookie of the year). We fought tooth and nail for every lap of every race and really put on a show. One of the clips of Jon and I racing side by side through the uphill esses has been viewed near 3 million times now on social media. https://www.instagram.com/p/DBozC8PRrpN/
Next up, Road Atlanta in December, then finally more than a few weeks off as I relax before VIR in march kicks off another busy season. Off season maintenance includes some improvements to the cage (mainly door bars) and maybe replacing/repainting my front bumper.
  • 1 month later...
Road Atlanta was fun!
My goal for the weekend was to match or beat the super old Spec3 record from one of the only other times the class had raced there about a decade ago, 1:43.X
I showed up super late on Friday and didn't do a practice day. I got about 5 green laps to learn the track between practice and qualifying (them boys down there sure do love to cause yellows), and I was able to beat the old lap record (at the same time as Charles and Andy doing the same) and ran a 1:41 in the race.
Unfortunately my weekend was cut short Sunday morning as a Miata that we were passing for the second time in one race went wide in turn 10a and essentially stopped on track. I was already in the braking zone 400 feet back when this started to transpire and had nowhere to go when he decided to cut back across the track and we met at the apex. Sometimes I do wish we had a rule about pace. If you're 20 seconds off pace, you should probably go back to HPDE. Their car was really no worse for wear but mine took quite a bit of damage. I dragged it back onto the trailer with a control arm looking like a pretzel and made the 14 hour tow back home early.
Offseason work will be replacing body panels, suspension, and steering components from the Miata thing. Since the bumper needs to be replaced, I may go back to a non-M bumper since the two fastest guys run one. Maybe there's something to it. Now that I've reached that upper tier and find myself duking it out with the fast guys on occasion, a focus on aero is probably warranted (but unlikely to happen).
The car is uglier than ever with every body panel having some kind of blemish after nearly 150 hard races, but until I find a sponsor to pay for a wrap, I think we'll keep schlepping the ugly green machine back out.
2025 looks to be another huge year for Spec3. The class has nearly quadrupled in size in the last 3 years and where I had exactly 7 race weekends possible in 2022, I have my choice of 30+ race events to choose to race Spec3 at. I may try to run some Great Lakes with the new guys there and of course the NASA Championships at Ozarks is on the docket. My only real concern is my engine. It has had 100+ races on it and I don't take good care of it (oil change once every 20 races or so) and it is making more power than I expect (but still legal). Some people say that engines make more power before they explode, so we'll see. Given my schedule in 2025 of racing just about every 2 weeks, I'm not sure I'll have time for an engine swap without missing one or two events and I don't have space in my townhouse to pre-emptively prep a motor.
We will see!
  • 3 months later...
Of to a great start this year!
Got the bumper, nose panel, fender situation all straightened out. I love the look of the 92 non M bumper. I also found the source of my sloppy steering, which was a loose nut on the upper steering shaft coupler. It's probably been like this for 2+ seasons and fixing this immediately improved my confidence in the car. It's definitely been holding me back and causing "busy" hands as the steering had a good 10-15 degrees of play in it before. I also adjusted my seating position forward to have a better command of the wheel and I feel even more comfortable in the car.
March VIR was my first event on the new Toyo R for Spec3 and the better tire combined with lots of iRacing, video review, and data analysis led me to a new PB only a bit off the existing lap record. This PB came on the sticker cycle for the tires on friday in a practice session.
I was able to stick with the leaders for most of the weekend and had some excellent battles with Sean. I qualified P2 for the rain race Sunday morning and was able to hold the lead for half of the race but I backed off a bit as the rain got heavier as I was P1 overall as well and had no tire tracks to follow. Sean O'hara caught me and passed me at a pace I wasn't willing to go in a torrential downpour. I still managed the fastest lap.
April Summit Point was more of the same. New PB close to the existing lap record. Lots of really great battles, podiums in each race in a large field.
Next up. Hyperfest! We hope to have 20 Spec3 cars across racing and HPDE
