Daria91 Posted August 1, 2021 Posted August 1, 2021 M50 Inline-6 motor swap 5-speed ZF320 transmission Refreshed limited slip differential with new clutches Full caged interior by Raven Cobra Evolution pro seat with lateral head restraint OMP 5-point harnesses OMP Superquadro steering wheel with quick release VDO gauges on a custom aluminum dash OMP Aluminum Pedals UUC Front big brake kit BimmerWorld brake cooling kit Hawk DTC-60 front pads and HT10 rear pads UUC stainless steel brake lines Bilstein Sport Shocks H&R Sport Springs H&R 20mm wheel spacers BimmerWorld Race Wheel Studs Light weight alloy wheels with Toyo RA1s Front strut tower brace Power windows still operating Heater core still in car New battery. $12,000 Canadian (approx $9200 USD) Extensive OPTIONAL spares package: E30 vented fiberglass hood (needs paint) E30 Rear rotors E30 light bulbs E30 Brake light switch (under brake pedal) E30 front hub nuts & caps E30 wheel bearing hub (new) E30 Hengst fuel filter E30 MANN fuel filter E30 relays E30 spark plugs x 2 sets E30 transmission mounts E30 exhaust hangers (new) x 2 E30 Steering rack boot E30 rear lense covers E30 front grille E30 wiper arms and blades E30 UUC front braded brake lines (1 set) E30 UUC Rear braded brake lines (2 sets) E30 fuel pump (Beck/Arnley) Set of 4 black rims w/Toyo Proxes RR 205/50-15 3 spare 15x7 black Monoblock rims RONAL ACT 7.5"x16" 4-bolt silver rims (5 rims) Set of 4 Toyo R888 225/45-15 4 extra wheel studs and nuts Rear brake bleeder screw, line brackets and nuts Hawk DTC-60 front pads for UUC rotors (2 sets) new Hawk HT10 rear pads (1 set) new Spare Sparco passenger seat (expired) & rails Schroth Harness for passenger side M50 Pressure plate clutch disc M50 Bosch (hard to find) ignition coils x 12 M50 E36 starter x 2 units M50 engine mount M50 tensioner pulley M50 serpentine belt M50 alternator M50 injectors M50 MAF sensor M50 water pump and thermostat M50 valve cover bolt gromets Spares package $2000 Canadian (approx $1550 USD) with car, $3000 Canadian (approx $2300 USD) without car Quote
Daria91 Posted August 27, 2021 Author Posted August 27, 2021 Price reduced to $10,500 Canadian = approx $7,900 USD Quote
