TaylorGoesFast Posted October 8, 2021 Share Posted October 8, 2021 (edited) If you want to build a Spec3 (who doesn't?!?!), this parts list should give you an easy solution to just click through and buy every part you need. https://docs.google.com/spreadsheets/d/1OlOMni51nbqwuyZUN7aE8V9y77sN1THtBnFW9rwHqmM This is a work in progress and we are still fine tuning it. This, coupled with the Constructor's guide, should make it very easy to get your build started and completed in no time! Last updated 4/5/23 Part Quantity Part Number Parts Link Price (as of 4/5/23) Spec3 Full Suspension Kit Front Sway Bar 1 70824 https://www.bimmerworld.com/H-R-Sway-Bar-E36-M3-Front.html $307.95 Rear Sway Bar 1 71824 https://www.bimmerworld.com/H-R-Sway-Bar-E36-M3-Rear.html $289.95 Front sway bar endlinks (can reuse stock rear) 2 https://www.fcpeuro.com/products/bmw-swaybar-link-front-31352227203my $35.18 Front Strut inserts 2 8641 1342SPORT https://www.fcpeuro.com/products/bmw-strut-assembly-koni-sport-86411342sport?fbclid=IwAR2nS5tZ9Okn5ltXgNm1ajqWaAqQNRUlrrdoZ68iHtspSeU_WRiiE9CPPDw 388.86 Front bump stops 2 31-33-2-225-377 https://www.bimmerworld.com/Suspension-Steering/Camber-Caster-Parts/OEM-BMW-Front-Axle-Bump-Stop-31332225377.html 58.56 Rear Shocks 2 8240 1115SPORT https://www.fcpeuro.com/products/bmw-shock-absorber-koni-sport-82401115sport?fbclid=IwAR2GiOuwyuRFpcqiQEDRZNdKXyMhpMI3joU0nHbqsHff-vpFj-vUtZ4obFo 277.76 Rear shock bump stop 2 33-53-1-138-109 https://www.fcpeuro.com/products/bmw-shock-bump-stop-rear-33531138109 17.98 Camber Plates 1 vorshlag-camber-plate-and-perch-kit-for-spec3 https://vorshlag-store.com/products/vorshlag-camber-plate-and-perch-kit-for-spec3?_pos=1&_sid=611d7db9f&_ss=r 635 RTAB Limiters 1 Many options available BMW Rear Trailing Arm Bushing Limiters - E36, E46, Z4 - AKG Motorsport 40 RTABs 2 33-32-6-770-817 fcpeuro.com/products/bmw-trailing-arm-bushing-outer-e36-e46-33326770786 17.98 Front control arm left 1 31 12 2 228 461.Genuine https://www.bimmerworld.com/E36-M3-MZ3-96-Front-Control-Arm-Left-Side.html 284.2 Front Control arm right 1 31 12 2 228 462.Genuine https://www.bimmerworld.com/E36-M3-MZ3-96-Front-Control-Arm-Right-Side.html 284.2 If buying used arms (recommended), press the following ball joints in to refresh the arm. YOU MUST USE THE LEMFORDER E30 M3 PART AS ALL OTHERS ARE NOT HEAT TREATED Outer Ball Joint 2 31121126254 https://www.fcpeuro.com/products/bmw-ball-joint-front-outer-31121126254l Optional Inner Ball Joint 2 31121126253 https://www.fcpeuro.com/products/bmw-front-inner-ball-joint-e30-lemforder-31121126253l Optional Front strut housing left 1 31-31-2-228-007 recommend buying a used set from junkyard or online seller https://www.fcpeuro.com/products/bmw-strut-assembly-front-left-m3-e36-312-2533 $50 Front strut housing right 1 31-31-2-228-008 recommend buying a used set from junkyard or online seller https://www.fcpeuro.com/products/bmw-strut-assembly-front-right-m3-e36-312-252 $50 Springs 4 Spec Part https://www.rrtautomotive.com/product/spec-3-spring-kit/ 703-661-4222 or [email protected] 350 Rear outer lower Ball Joints (replaces stock non M BUSHING) 2 stock m3 33326775551 https://www.fcpeuro.com/products/bmw-trailing-arm-ball-joint-e36-e46-33326775551 55.58 Rear outer upper ball joint 2 stock m3 33326775551 https://www.fcpeuro.com/products/bmw-trailing-arm-ball-joint-e36-e46-33326775551 55.58 Rear inner lower ball joint 2 stock m3 33326770824l https://www.fcpeuro.com/products/bmw-control-arm-bushing-rear-lower-inner-oem-33326770824l 15.98 Rear inner upper ball joint 2 stock m3 33321092247 https://www.fcpeuro.com/products/bmw-control-arm-bushing-rear-upper-e36-e46-oem-33321092247 19.18 Rear shock mount 2 STOCK https://www.bimmerworld.com/Rear-Shock-Mounts-RSM-OEM-Standard-E36-E36-E46-Z3-Z4-Pair-BMW-33521137972.html 21.98 Race Studs 1 Many options available https://www.fcpeuro.com/products/bmw-m12x1-5mm-wheel-stud-kit-78mm-motorsport-hardware-12x1578mmbrskt 155 Front Control Arm Bushings 1 e36 m3 stock bushing BMW Control Arm Bushing Kit - Lemforder 31129069035 | FCP Euro $30.79 Subframe Bushings 1 Many options available https://www.akgmotorsport.com/product/rear-subframe-bushing-set-for-bmw-e36-not-318ti-polyurethane-75d/ 190 Engine Mounts Many options available BMW Motor Mounts, Poly 75D - E36, E46, Z3, Z4 - AKG Motorsport Optional Transmission Mounts Many options available - E46 M3 OEM upgrade option shown BMW Transmission Mount - Genuine BMW 23711109173 | FCP Euro Optional 3.15 LSD Danville Diffs - BMW Differential, REM Gear Polishing 300 Differential Bushings Many options available BMW Differential Bushing FRONT 14mm, Aluminum - E36 - AKG Motorsport OR https://www.akgmotorsport.com/product/differential-mount-bushing-front-for-oversized-bolt-poly-75d-e36/ 130 Engine Management ECU Chip 1 217.12.536.0003 https://www.bimmerworld.com/Spec3-Performance-Chip-by-Epic-Motorsports_2.html 200 K&N Air Filter 1 33-2070 https://www.knfilters.com/bmw/325is/2.5l-l6-gas/1994/ 50 Spec3 Chassis Reinforcement Kit Subframe reinforcement 1 Many options available https://www.akgmotorsport.com/product/rear-subframe-reinforcement-plates-e36/ 185 Rear Shock reinforcement 1 Many options available https://www.akgmotorsport.com/product/rear-shock-mount-reinforcement-set-e30-e36-e46-z3/ 20 Rear sway bar reinformcent 1 Many options available https://www.akgmotorsport.com/product/rear-sway-bar-reinforcement-plates-bmw-e36/ 20 RTAB reinforcement 1 Many options available https://www.akgmotorsport.com/product/rear-trailing-arm-reinforcement-plates-e36/ 25 Front Subframe reinforcement 1 Many options available https://www.akgmotorsport.com/product/front-subframe-engine-mount-reinforcement-plates-e36/ 19.99 Front strut tower reinformcent 2 Many options available https://www.bimmerworld.com/Front-Strut-Tower-Reinforcement-Plates-E36.html 34.98 X brace kit 1 OEM Part https://www.bimmerworld.com/BMW-Motorsport-E36-3-Series-Z3-X-Brace-Kit.html Optional Oil Pan Kit Drilled Oil Pump nut 1 driver choice - optional https://www.bimmerworld.com/M50-Drilled-Oil-Pump-Nut_2.html optional Baffle 1 driver choice - optional https://www.bimmerworld.com/Engine/BMW-Oil-System/Oil-Pan-Baffle-E36-Z3-6-Cyl-All-M50-M52-S50-S52.html optional Gasket 1 driver choice - optional https://www.bimmerworld.com/Engine/Gaskets/Oil-Pan-Gasket-11-13-1-437-237.html Optional Magnetic Drain Plug 1 driver choice - optional https://www.bimmerworld.com/Magnetic-Oil-Drain-Plug.html Optional Reinforced Z3 Pickup tube 1 11411703930 https://www.fcpeuro.com/products/bmw-suction-pipe-11411703930 Optional Oil pickup tube gasket 1 11411703947 https://www.fcpeuro.com/products/bmw-oil-pump-gasket-11411703947 Optional Spec3 Cooling System Kit Water pump 1 Many options available https://www.fcpeuro.com/products/bmw-water-pump-emp-stewart-888010330 Optional Aluminum Radiator 1 Many options available BMW Aluminum Radiator - Mishimoto MMRAD-E36-92 | FCP Euro Optional Fan 1 Many options available https://www.bimmerworld.com/SPAL-16-Low-Profile-Fan-Push-Straight.html Optional Water pump nut 1 Many options available https://www.bimmerworld.com/Water-Pump-Shaft-Nut.html Optional Spec3 Brake Kit Front DTC-60 1 Spec part https://andrew-racing.com/i-23456440-nasa-spec-3-front-nbs3f.html 140 Rear DTC-60 1 Spec part https://andrew-racing.com/i-23456441-nasa-spec-3-rear-nbs3r.html 140 Front Rotors 2 Many options available https://www.fcpeuro.com/products/bmw-brake-rotor-front-e36-e46-e85-z3-zimmermann-34116864060 104 Rear Rotor 2 Many options available https://www.fcpeuro.com/products/bmw-brake-disc-zimmermann-34216794305 67.8 Stainless brake lines 1 Many options available https://www.bimmerworld.com/BimmerWorld-E36-6-Line-Stainless-Steel-Brake-Line-Kit.html Optional Fiberglass headlight intake https://www.ebay.com/itm/BMW-E36-Headlight-Air-Duct-Insert-For-Spec3/284060071541 optional Race German Headlight Intake https://racegerman.com/products/e36-headlight-duct optional (ask about Spec3 discount) Aero Appearance Kit M3 bumper https://www.bimmerworld.com/E36-M3-Style-Front-Bumper-Spoiler-Kit-1992-1999-318i-325i-328i.html Optional SSI Undertray https://www.bimmerworld.com/Body-Aero/Front-Spoilers/SSI-Stealth-Underpanel-E36-3-Series.html Optional Other Racing Seat 1 Many options available OMP RS-PT2 Fiberglass Racing Seat – OG Racing $789.00 6 point harness 1 Many options available Sparco FIA 6-Point Racing Harness - Steel, Pull-Up Lap Adjusters – OG Racing 299 Fire System 1 Many options available https://www.ogracing.com/products/lifeline-zero-2000-fire-marshal-fia-fire-system-4-liter-mechanical 400 Rain Light 1 Many options available https://www.ogracing.com/products/lifeline-fia-led-rain-light 150 17x8.5 or 17x8 wheels 4 Many options available https://konigwheels.com/nasa-spec-3/ 659.76 235/40/17 Toyo RR 4 Spec Part https://philstireservice.com/product/toyo-proxes-rr/ 1152.92 Seat Adapters 1 Many options available https://www.bimmerworld.com/BimmerWorld-Billet-Aluminum-Seat-Floor-Mount-Adapters.html 190 Side mount brackets 1 Many options available https://www.bimmerworld.com/OMP-Steel-Seat-Side-Mount-Set-Low.html 70 Roll bar padding 3 Many options available https://www.bimmerworld.com/SFI-Spec-Hi-Energy-Cage-Padding.html 53.97 Steering wheel hub 1 Many options available https://www.bimmerworld.com/OMP-Steering-Wheel-Hub-Adaptor-E36.html optional Steering Wheel 1 Many options available https://www.bimmerworld.com/OMP-WRC-Steering-Wheel.html optional Brass Caliper Bushings 2 Many options available https://www.bimmerworld.com/Brakes/Caliper-Parts/BimmerWorld-Solid-Brake-Guide-Kit-Most-ATE-Calipers.html Optional Clutch Stop 1 Many options available https://www.bimmerworld.com/BimmerWorld-Junior-Puck-Clutch-Stop.html Optional 6 Pole Kill Switch 1 Many options available https://www.ogracing.com/products/battery-6-pole-killswitch?_pos=1&_sid=92373c78a&_ss=r 45 Window Net 1 Many options available https://www.ogracing.com/products/g-force-window-net-ribbon-style?variant=31776320061506 25 Window Net Kit 1 Many options available https://www.ogracing.com/products/joes-racing-products-window-net-mounting-kit-2?_pos=3&_sid=99909763f&_ss=r 100 Center Net 1 Many options available https://www.ogracing.com/products/g-force-driver-side-net?_pos=2&_sid=eab4b9126&_ss=r Optional Tow Hooks 2 Many options available https://www.akgmotorsport.com/product/motorsport-racing-tow-hook-set-aluminum-e36-m3/ Optional Heater Core Delete Panel 1 https://www.hardmotorsport.com/hard-motorsport-firewall-hvac-block-off-plate-bmw-e36/ Optional Spec3 Exhaust 1 Mitchum Enterprises Richmond, VA (804) 402 1239; [email protected] 400 Total 9403.13 Edited May 12 by TaylorGoesFast Quote Link to comment Share on other sites More sharing options...
TaylorGoesFast Posted April 5 Author Share Posted April 5 Updated prices and parts 4/5/23 Quote Link to comment Share on other sites More sharing options...
TaylorGoesFast Posted May 12 Author Share Posted May 12 Added bump stops Quote Link to comment Share on other sites More sharing options...
