ssmith Posted October 8, 2021 Share Posted October 8, 2021 The rules state in 6.5.1 (2): Any "Adjusted Weight/Power Ratio" calculation ending in ".995" (xx.995) or greater will be rounded up to the benefit of the competitor. If you enter ST4, 2454 lbs, 266mm tires or smaller, and a -0.2 additional mod factor, the calculator says the declared power is 207 with a total mod factor of 0.2. However, 2454 / 208 (not 207) = 11.798. Add the 0.2 total mod factor gives you 11.998, which should round up to 12. Small bug I know... Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted November 10, 2021 National Staff Share Posted November 10, 2021 That would factor in if we had to calculate an Adjusted Wt/HP Ratio in tech. For the calculator, just add one more pound of weight, and it gives you the 208 HP. Quote Link to comment Share on other sites More sharing options...
