Administrators Roman V. Posted December 7, 2021 Administrators Share Posted December 7, 2021 This is just a calculator. The submission portion will be activated by the end of the year. Enjoy! If you see any issues, please report them here. https://form.jotform.com/drivenasa/2022-nasa-st-tt-calculator Link to comment Share on other sites More sharing options...
rsotak Posted December 8, 2021 Share Posted December 8, 2021 (edited) It looks like the form for ST/TT4 allows for the use of under 266mm (+0.6) or 267-282mm (+0.3) tires with varying bonuses regardless of weight. I don’t think that jives with the tire rules, or am I missing something. Is this throwing off the final calculation Edited December 8, 2021 by rsotak Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 8, 2021 National Staff Share Posted December 8, 2021 4 hours ago, rsotak said: It looks like the form for ST/TT4 allows for the use of under 266mm (+0.6) or 267-282mm (+0.3) tires with varying bonuses regardless of weight. I don’t think that jives with the tire rules, or am I missing something. Is this throwing off the final calculation This would be a time when the driver needs to actually know the rules and choose the correct tire size. There was something about the programming of this system that was difficult to remove the larger tire option from the list if the car was lighter weight. Link to comment Share on other sites More sharing options...
rsotak Posted December 8, 2021 Share Posted December 8, 2021 (edited) That makes sense, but is going to lead to some confusion during impound I would predict. Can wording be included around the weight limits on the lines in the calculator to remind people that they can select the larger tire under 3000lb? Edited December 8, 2021 by rsotak Link to comment Share on other sites More sharing options...
Administrators Roman V. Posted December 8, 2021 Author Administrators Share Posted December 8, 2021 1 hour ago, rsotak said: That makes sense, but is going to lead to some confusion during impound I would predict. Can wording be included around the weight limits on the lines in the calculator to remind people that they can select the larger tire under 3000lb? You can run a smaller tire when over 3000lb not another way around. We might make some changes to the way it operates or just wording changes. Link to comment Share on other sites More sharing options...
rsotak Posted December 8, 2021 Share Posted December 8, 2021 Yep meant "can't" to the larger tire under 3000lb Link to comment Share on other sites More sharing options...
Administrators Roman V. Posted December 8, 2021 Author Administrators Share Posted December 8, 2021 13 minutes ago, rsotak said: Yep meant "can't" to the larger tire under 3000lb I said "can run a smaller tire when over 3000lb". So in another way around you can't run a larger tire when under or equal to 3000lb. Link to comment Share on other sites More sharing options...
