countryboyshane Posted March 13, 2022 Share Posted March 13, 2022 (edited) SOLD SOLD SOLD https://flic.kr/s/aHBqjzFBAy For sale is a 1995 BMW M3 race car with a highly desirable S54 engine swap. This would be a perfect car for SCCA and NASA Super Touring classes, BMW CCA, Grid Life, or even a super safe track day/HPDE car. The car handles like a dream, driving at the limit of grip, incredible bottom end torque, and God-like braking capability thanks to the Teves standalone ABS. You will love it! Priced to move at $29,500! I’m the fourth owner of the car and intended to compete in the NASA Super Touring 4 class. I bought the car as a turn-key racecar February 2020 and have barely done anything to it except for the following: Swap from 18” to 17” wheels. Removed one billion stickers Replace front quarter panels. Removed non-legal rear wheel flares that were damaged anyway. The only reason I am selling it is because I’d rather have the cash to make an investment play that I want to make for my business. The prior owners threw almost every part of the Bimmerworld and Turner Motorsport catalog at this car. Easily $70K worth of upgrades. The S54 engine has had all the major updates to it to make it bulletproof. MUCH MORE PHOTOS AVAILABLE VIA GOOGLE DRIVE. PLEASE ASK FOR LINK. Engine S54 swap (E46 M3 engine) rebuilt by TKX Performance, NY Rebuilt and installed December 2019 EPIC treated rod bearings Schrick race cams - 288/250 12.5mm lift Schrick DLC coated rocker arms JE pistons ARP rod bolts ARP head bolts ARP main bearing cap bolts Beisan S54 Vanos anti-rattle kit Vanos sprocket updated bolts All other Vanos parts updated with Dr. Vanos Supertech valve springs and retainers Cometic MLS head gasket BMW motorsport thermostat Turner oil cooler adapter kit ECU Calibrations Professionally tuned by Randy Mueller at Epic Motorsports Comes with 2 ECUs. One with max power calibration, and the other (which is currently installed on car) with NASA ST4 compliant tune. All are tuned for 93 octane gasoline. Peak power calibration - 355whp @ 8200 rpm NASA ST4 tune - 260whp @ 8200 rpm Epic Motorsports ECU tune cable. NOTE: Car was tuned before the ONE WEEKEND that I drove this car. It pulls strong! Exhaust Epic Motorsports catless header Custom 3” exhaust to Borla muffler Transmission 5-speed E36 manual transmission Solid mounts Differential Vented rear diff case with catch can Reinforced diff mounting Diffs Online Differential Rogue finned differential cover Front Suspension MCS 3-way adjustable coilovers w/Eibach springs - rebuilt in 2019 and have one weekend on them. Ground control camber plates with spherical bearings Ground control adjustable sway-bar with spherical ball-end links. Turner roll center correction kit with spherical bearings Strut tower reinforcement plates Rear Suspension MCS 3-way adjustable coilovers w/Eibach springs - rebuilt in 2019 and have one weekend on them. Turner adjustable trailing arms with ball ends Strut reinforcement plates Reinforced trailing arm pockets Ground Control rear sway bar + end links with solid rod ends. NOTE: The rear wheel wells have been cut, expanded and sealed to accommodate large 18” wheels, up to 275mm in section width. Brakes Teves Mk.60 standalone ABS system Front - PFC 2-piece semi-floating rotors Rear - E46 brake disks Alcon big brake kit Cooling ducts Exterior Fiberglass front hood with carbon fiber insert Carbon fiber sunroof delete panel Hard Motorsport front wheel flares Rear wheel wells have been expanded to accommodate 18” wheels Carbon fiber trunk lid Interior AIM MXL dashboard (does not log data) SCCA, NASA, BMW CCA compliant roll cage Fire system Seat Belts Coolsuit Schroth 6-point harness (belts expired 2021) Safecraft driver’s window net (expires June 2022) Schroth window net (expired 2021) Safecraft 5 pound fire extinguisher Sparco removable steering wheel Racetech 119 FIA compliant seat NOTE: When I received the car, I found out that the rear spare tire well was completely cut out for weight savings. I had a local fabricator add in a boxed area so I had a location to add ballast weight (like barbells). Aerodynamics Bimmerworld rear wing with tall uprights Front splitter that runs all the way to back of rear subframe Cooling System CSF radiator CSF front mounted oil cooler Manually operated SPAL 16” puller fan Other Chassis Notes Chassis has about 150,000 miles on the odometer, but every maintenance related bearing has always been replaced. Receipts available. Wheels Comes with 17”x9” wheels wrapped in old Hoosier H20’s. Two sets of APEX 17”x9” wheels with Hoosier R7s available at extra cost. The car has a few things that need attention: Driveshaft guibo and center support bearing need to be replaced. This should be addressed before taking to the next track event. Windshield has a foot long crack coming from the lower driver side corner. Lastly, this car does not have a title. I don’t see why you would even want one for a fully caged racecar that has absolutely nothing to deem it safe on the road. Always glad to take questions or even a phone call. Please message me. -Shane Gorski Edited March 13, 2022 by countryboyshane Quote Link to comment Share on other sites More sharing options...
