EG CX shell with D16z Ex drive train. Class?
I belieive this combo is H4, I just starting to build this car, and I would like to make sure of this. Also is this set up competitive?.. Anyone else running this set up?
Using the chassis swap rule, you can run this in H4 as if it were a 5th gen. Civic Si. Remember, that you must switch over all of the running gear for it to be a legimate swap. eg front & rear suspension, brakes, engine & tranny. Other things are open per the rules. eg. swaybars, final drive in tranny, engine harness, lack of sunroof, etc
I'm building one for NorCal (Mike, I'm sure by now you think it's never gonna happen, but you know the mechanic !) It's probably not going to be ready before Nationals, at least not in time for me to run enough events in it to qualify for Nationals, so I'm probably going to stick with the stock VX eng and trans until after Sept, even if I now have to drag my feet a little with the mechanic . I really don't think we can get it ready before June...
