1995 Mustang American Iron Griggs/Dart/TKO600RR/Tiger Racinf
Posted (edited)
$30,000 or best offer. My name is Brad and my phone number is 765-714-4358.
This car has the best of everything and no expense was spared. I have a Texas title for the car.
Engine: Dart block .040 over 349”, RPM neutral balance crank, unknown forged rods, Wiseco pistons, custom Comp cam, conical valve springs, ARP pushrods, rocker stud girdle, FRPP road race oil pan, Melling H/V oil pump, massive Fluidyne oil cooler, Fluidyne aluminum radiator, factory fan, Edelbrock water pump, ARP fasteners throughout
Ignition: MSD billet distributor, MSD ignition box, MSD wires, MSD coil
Fuel: Holley 650dp carb, Aeromotive FPR, -6an supply and return lines, Holley external pump, UPR pickup.
Steering: KRC power steering pump, Earls cooler, 2003 Cobra rack, FRPP Sparco steering wheel
Drivetrain: TKO600RR trans, Quartermaster triple disc clutch, Tremec shifter, Griggs steel driveshaft, cambered hybrid 8.8 rear with 9” end, Torsten diff, 3.73 gears(I’m pretty sure).
Brakes: Griggs 4on4 brakes front and rear, new front rotors and pads, spare front rotors included, stainless lines, front cooling ducts integrated into the front pumper, factory booster and master cylinder, 1995 ABS
Body: Tiger racing carbon fenders, doors, hood, and front bumper. Custom rear flares (can fit 315’s all way round), glass windshield, lexan quarter windows and back window, G Stream rear carbon wing, carbon splitter.
Suspension: Griggs SLA system, Koni double adjustable shocks and Griggs coil overs, Griggs watts link, Griggs torque arm.
Misc: hard wired transponder, big rear view mirror, Cool suit cooler with integrated helmet blower, Autometer gauges, wide band, Powermaster alternator, Powermaster starter, OMP full containment seat (expired but comes with back brace), 6 point belts expired, window net expired, Enkei RPF1 wheels, ARP wheel studs, battery mounted in rear.
Spares: ignition box and distributor, comes with steel and carbon doors (both painted to match and stickered up), an extra set of ENKEI RPF1 wheels with Toyo RR’s mounted, new Carter fuel pump and filter.
Edited by goindeafonmtx
Added info.
