Sal Posted April 5, 2022 Share Posted April 5, 2022 Photos: https://bit.ly/3J6jPPT I'm selling my SpecE46 - it has all the components of the race class except the required full cage. Perfect car to start on HPDE and work your way up to Time Trials or the full Spec E46 Race Class. It has the SpecE46 full suspension and race exhaust. The original engine had 130K miles on it, but was rebuilt with the short block from a M54 that I got off an automatic 530i that had 70K miles on it. The cylinder head was machined and new bearings installed. I have receipts for everything you see on this list. The engine was rebuilt in 2021 and has a total of 5 track days on it after break-in of new engine BUILD DETAILS: Safecraft Racing Harness Oil Ban Baffle BMW Cylinder Head Gasket BMW BKR6EQUP Spark Plug VDO Fuel Pump Bosch Ignition Coils Crankshaft sensor Camshaft Sensor 1 Camshaft Sensor 2 PCV System Crank and Transmission Seals Clutch Kit Vacuum Hose Brake Booster Hose 95A Durometer Transmission Mount Guibo Gearshift Bushing Vaccum Pump Mount Shifter Bushing Mass Air Flor Sensor (MAF) Radiator Hoses Fidanza Flywheel Belt BMW Pro 5 Air Filter Glyco Main Bearings Connecting Rod Bearings BMW Thermostat Assembly" BMW Steering Coupling Assembly M54 Heater Core Delete Kit Kirk Racing 4 Point Roll Bar - E46 BimmerWorld Full Race Exhaust By Magnaflow - E46 323i/325i/328i/330i (Header-Back) 255/40R17 Bridgestone Potenza RE-71R 17X8.5 5-120 ET40 FLOW ONE F2# Sparco Pro2000 Plus Seat OMP Steering Wheel NRG Quick Release Steering Wheel Hub E46 Control Arm Myle Right+Left Hyperco 2.25" Coil Spring (185A0850) x 2, Hyperco 2.25" Coil Spring (186A0750) x 2, Condor E46 FCAB Replacement Inserts (CNDR-E46-FCAB-BSHNG-21) x 1, E36 & E46 Articulating Spring Perches Only (RE-ASP-E46-PERCH-PR) x 1, Rogue Engineering E36 & E46 Spring Alignment Cones (SPR-PER2.25) x 1, Vorshlag Spherical RSM – Mount Only (E36-RSM-VM-12-1) x 1, Spec E46 Suspension Kit (Complete) (MSW-SE46-SUSPENSION-KIT) x 1, MCS E46 Single Adjustable Damper Set (E46.1WNR) x 1, Vorshlag BMW E46 & Z4 Non-M Camber Plates (VOR-E46-NM-CAMBER-PLATE) x 1, E46 Solid Front "Eyeball" Control Arm Bushings (brackets only) (CON-E46-CAB-BRKT) x 1, Front Adjustable End Links E46 10-11.5" (100.31.546.0001) x 1, SPL E36 & E46 RLL Rear Camber Arms (SPL-RLL-E36) x 1, Powerflex Rear Trailing Arm Bushing E36 / E46 (PFR5-3608Bx2) x 1 shipped via UPS on August 24, 2020 with tracking number M54 Rebuilt Engine - 71,000 miles Rear Seat Original Cylinder Head (un-machined), 130K miles Original Driver's Seat 4 Wheels, 6 spoke street wheels Original Steering Wheel with Airbag Quote Link to comment Share on other sites More sharing options...
