Steve Graves Posted February 21, 2006 Posted February 21, 2006 The #81 3rd gen. CMC Camaro is now for sale at $7,000. 1983 Yellow and blue RS with '91 ground effects, '91 roller-cam engine, carbon fiber adjustable rear wing, custom front air-dam, Koni's front and rear, 1000# fronts and 300# rears, WS6 steering box, master cut-off switch, new battery (box re-located to P.S. rear seat), set up for night enduros (4 high-beams and 4 bullet lights below), stock alt. and 160 amp for lights,Momo competition 13" steering wheel with quick release, adjustable Sheel-Mann padded rally seat, pedals set up for easy heel/toe, 2 sets Kelsey Hayes light-weight 16x8 wheels, one set '91IROCS, 1/2" Nascar wheel studs, fresh brake pads and rotors, PBR calipers, rear brake bias, pro-welded roll cage with Nascar-style door bars, large front and rear sway-bars,tower brace, caster/camber plates, s.s. braided brake lines, 600 cfm Holley #4776, large flat rear-view mirror, 5-lb. Halon fire system with 2 engine compartment and 1 D.S. interior sprayers, 16 gallon Fuel Safe cell, Holley Red electric fuel pump mounted at cell, 5" Autometer tach, front window clips and rear straps, Borg Warner World-Class T5 tranny with .83 5th gear, B&M billet short-throw shifter, fresh clutch, 3.73 locked and cambered Borg-Warner Austrailian 9-bolt rear end, fiberglass hood, Griffin aluminum radiator, electric fan, under-drive engine and alt. pulleys, power steering cooler, straight 3" exhaust, All Royal Purple lubricants, car cover, 6th place finish in 2004, 1-1st place finish at Reno/Fernley, Nasa and Scca log-books. Also not on car: 3-quart Accusump, Earls oil cooler, Holley #4776 four-barrel and single-chamber Flowmaster. Car is in Paso Robles, Ca. I can E-mail pictures. Steve Graves, Quote
Steve Graves Posted October 19, 2006 Author Posted October 19, 2006 Now $6000, $5700 without Halon system. Great Deal. Thanx, Steve... Quote
Steve Graves Posted November 9, 2006 Author Posted November 9, 2006 Hi Derrick, Check this out. Thanx, Steve... Quote
