jmshriver Posted June 21 Share Posted June 21 I am looking to sell my 1997 BMW M3 that is currently set up for TT4. I bought the car in 2015 with a salvage title to turn it into a dedicated track car. I had the car checked out to ensure that it was properly repaired and a good candidate for track use. The car runs strong and will be super competitive with any driver. The car currently fits into TT4 but still has room to either shave more weight or add some power. Last time the car was on the scales it weighed 2770 with me in it. The car is street legal with collector car insurance. Car will come with the factory wheels and whatever parts I have laying around. Engine Mods: Converted to OBD1 for a Link stand alone ECU and tuned by UMS (267hp peak, 257hp avg, 252trq) Active Autowerke headers BimmerWorld Race Exhaust Injector Dynamics 1050 injectors M50 manifold conversion Dinan intake Turner Motorsports under drive pulleys Transmission/Driveline mods: 3.91 LSD differential with solid mounts UUC shifter with DSSR Suspension/Chassis/Brake mods: Ksport Kontrol Plus coilovers with external reservoirs Stoptech rotors with Raybestos ST47 pads and high temp fluid Aligned and corner balanced by Flatout Motorworx Wheels/Tires: 17x9 Apex Arc-8 wheels 255/40/17 Maxxis RC1 tires (good for a couple more track days) Miscellaneous: BimmerWorld fuel starvation kit Antigravity battery Sunroof removed and replaced with color matched fiberglass panel ASC delete AC and heater core removed and blocked off properly Power steering removed OMP steering wheel Sparco Seats with VAC motorsports seat mounts Harness bar with Crow harnesses Cons: Driver side brake light is out Standard rock chips on the front bumper from track use Starter has intermittent problems but has never failed to start If you would like any more pictures or information, please don’t hesitate to contact me. Title in hand and ready to go. I am asking $17,500 OBO. Quote Link to comment Share on other sites More sharing options...
