ST6 97 Miata TURNKEY well sorted w/Title (GL 2021 winner)
Posted (edited)
Sorted Turnkey ready 2022 Annual NASA logbook completed. 6/17/2022 NASA dyno shows 139whp. WON 1st place 6/18 and 6/19 Gingerman 2022 NASA event!
Suspension:
- Xida coilovers with 900/600 spring ratings
- Racing Beat 1.125" front sway bar w/custom front spherical end links and Flying Miata rear sway bar with Flying Miata adjustable end links
- Extended lower ball joints
Brakes/Wheels:
- new front rotors and Hawk Blue race pads installed September 30, 2021 (used only one weekend after bedding in)
- Rear rotors and pads replaced May 2021 (hawk Blue pads)
- stainless steel brake lines
- Brofab front hubs/wheel bearing setup installed May 2021 (never a concern for breaking front hubs again)
- ARP extended studs all 4 corners
- 4 Konig Dekagram Bronze 15x8 4X100 ET25 wheels purchased June 2021 with Hoosier 205 50 15 tires
- 1 set of 'stock' miata wheels on 'stock' tires (to drive in the street if desired) and what the car sits during winter storage if not up on jackstands.
Engine/Trans/Diff:
- 4.77 Torsen Diff with poly bushings  (note this is not a factory stock option)
- 5x racing Shifter rebuild with bronze bushing
- typhoon intake system (air intake from removed bumper marker light)
- Spring 2021 brand new Mishimoto aluminium radiator
- Mtuned coolant reroute
- Master cylinder brace
- Cobalt hood lift kit from MOSS Miata (hood stays open easily with this)
- Running on MSPNP2  (has additional tune for E85 and ST5 available but running 93 for NASA ST6 now)
- Lower mileage BP4W 99 Miata engine installed May 2022 (68k mile engine was very clean inside)
- Timing Belt, VCG, Water Pump, front and rear main seal replaced May 2022 along with new spark plugs.
- Full Racing Beat race exhaust
- Racing Beat header
Interior
- Cage built by Wilson Racing Chassis with its first NASA log book issued July 30, 2020
- Momo D shape steering wheel with NRG 2nd gen self-centering quick release
- Momo Lesmo halo seat on Jerfspeed brackets
- Wink Mirror
- NACA window duct
- heat shielding for driver floor/tunnel area
- Longacre Accutech Water Temp/Oil Temp/Oil Pressure gauges
Innovate wideband AFR
- programmable shift light guage
- Gforce 6 point harness (NASA Race valid until December 31, 2023)
- Window net valid through 2023 for NASA
- handheld fire extinguisher mounted in reach of driver
- blower setup for foggy or rainy days
- custom switch panel for wipers, cool suit, LED exterior lights, blower fan, fan
- FAST cooler wiring in place for trunk setup with swtich (FAST system not included)
Exterior/Body:
- OEM Miata hardtop with defrost (permanent bracket mounts-- no soft top)
- looped cable 'quick release' setup for fuel, trunk and hood release
- Aerocatch hood pins in addition to stock hood release
- Front hood support strut (keeps hood open on it's own- no possibility of flying closed or open)
- 2 Tow hooks in front- 1 in back
- headlights have been 'gutted' but custom fabricated metal brackets hold the headlight covers securely in place (they will never fly off the car or waiver)
- Stock windows custom set up to 'sit' in place when not in use for open trailer use or when sitting outside in rain, driving in the street, or overnight at the track
- Additional 'gutted' OEM alumium hood if new owner wanted a less weight option
Title status:
- clear, clean normal title (able to be titled by new owner if desired)  has toggle set up for directional signals inside the car
$15,800.00   (*no trades*)
Please note that ballast, traqmate, cool suit system and transponder is NOT included.
Edited by CWeber
missing info updated
