SergioMarron Posted August 15, 2022 Share Posted August 15, 2022 Hi. 95 Civic Dx with rear disk brake upgrade. Swapped a in a 4040 prop Valve but was leaking at the threads. I went to junk yard and that one was leaking also. is there something I'm doing wrong? I Can't buy new prop Valve from Honda. should I just T the front lines and use aftermarket prop Valve? any guidance would be appreciated. Quote Link to comment Share on other sites More sharing options...
Shooting Brake Posted September 5, 2022 Share Posted September 5, 2022 Not sure what other HC competitors are using, but my 1994 BMW 325 had nonfunctional ABS even before it was converted to a track car. Pre-1996 E36 brake systems have a single line to a T to the rear calipers. After flat-spotting another pair of rear tires, I added a Wilwood proportion valve mid-point in the single line to the rear. Trial and error on a Test & Tune Day fine tuned the brakes. Quote Link to comment Share on other sites More sharing options...
