Classification Form Problems
Chip
I'm trying to submit my classification form for TT3 and am getting the following error:
***SUBMIT BUTTON IS DISABLED***
Please check the form for the following possible issues:
1. Manually, mechanically actuated throttle body (no electronic servo)
(Does not apply to forced induction vehicles)
2. DOT-approved: Tire size printed greater than 315 (ST2, ST3 Only) (Does not apply to vehicles with comp. weight over 3750 lbs)
3. Non-DOT-approved: Size greater than 11.8”/300mm/30 cm (ST2, ST3 Only) (Does not apply to vehicles with comp. weight over 3750 lbs)
4. NASA Section Width 257mm or less with MCW greater than 2749 lbs
5. NASA Section Width 226mm or less with MCW between 2400 lbs
and 2749 lbs
I suspect the problem is with number 2. I am using a 325 printed tire size. However, my competition weight is greater than 3750, so the form should allow me to submit. Seems like maybe a form validation error?
Chip
  • National Staff
and 2749 lbs
Chip
Chip,
Did  you get this issue addressed?   It is working for others that enter a weight over 3750 lbs.
  • Administrators
and 2749 lbs
Chip
You can’t use #2 if your comp weight is over 3750. That is why the form is not letting you submit.
Hi Gregg,
As Roman mentioned, I was able to submit by not selecting the radio button for tires over 315mm wide and choosing "Not Applicable" since my weight is over 3750 lbs. I would suggest that it may be better and clearer to instead have the logic on the back end that check weight and don't apply the 0.3 modifier if the vehicle is over 3750 lbs. On first read through it seemed that I should select the 315mm+ option because my tires are indeed wider than that, and I had to dig a little to find out that, since the modifier doesn't apply to me, I should choose "Not Applicable" for the field.
Chip
  • National Staff
Yeah, I thought he meant that he wasn't checking that button, and it wouldn't let him submit.
  • National Staff
3 minutes ago, Chip said:
Hi Gregg,
Chip
All of the logic is setup to only check buttons that apply to you, and will result in a Mod Factor assessment.  The reason that the exception is not listed right there is because of the length of the form (and people should know it doesn't apply from reading the rules).  But, since we don't want someone taking the Mod Factor when it doesn't apply, we have the "stop" and explanations at the bottom if the error is made.  We are someone limited by Jotform in how we do things.  We will hopefully be going to a proprietary program in '24 where we have more flexibility.
Understood. As long as that's the correct methodology given the existing form constraints, I've successfully submitted. Thanks for following up.
Chip
