BTM Aero
Shooting Brake
 Share
My E36 is a S52 swapped 1994 325is M-Tech. The grille in the front bumper cover is distinct compared to the M3. If I select BTM Aero on the ST/TT Worksheet does the front end have to be 325is style?
  • National Staff
Yes, because these things only apply if you are not taking the BTM Aero Mod Factor:
5) Modified BTM, non-Base Trim Model (non-BTM), or replaced front fascia (unless
specifically approved in Appendix B):
i) May have nothing attached to it other than specifically allowed items above.
ii) May not have canards/winglets molded into it.
iii) Any item that is molded into the fascia during the original manufacturing process that
functions as an airfoil, deflector, dive plane, or vortex generator and extends 2" or more past the
outline of the immediate surrounding fascia is prohibited. To inspect: a plumb line run across the
entire surface of the fascia and bumper shall not have any such item that extends 2” past the line
when viewed from above.
 Share
