mcmmotorsports Posted June 8, 2006 Share Posted June 8, 2006 I have been reading the AI Rules for '06 and noticed that it says the following: There is no minimum weight for 4 or 6 cylinder powered AI cars. Has anyone ever tried running a 4 cylinder car in AI? I know that you can get one (4cyl car) to scale out at around 2,100 lbs without driver. Curious as to how competitive or not competitive this would be. Quote Link to comment Share on other sites More sharing options...
coupe331 Posted June 9, 2006 Share Posted June 9, 2006 http://www.nasaforums.com/viewtopic.php?t=6163 Ryan Walton Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted June 9, 2006 Author Share Posted June 9, 2006 Thanks Ryan, I read that thread but didn't want to bring it back from the dead and besides, I was curious about an N/A 2.3, not Turbocharged. Quote Link to comment Share on other sites More sharing options...
King Matt Posted June 9, 2006 Share Posted June 9, 2006 There's been so much development to the 2.3 over the years that making the horsepower is no problem, but I have no idea what kind of torque they make in NA form. That might be an issue. What would be wicked would be an ex-Trans Am turbo four in AIX. Quote Link to comment Share on other sites More sharing options...
mikef Posted June 22, 2006 Share Posted June 22, 2006 My car is running and almost ready for tech inspection, after the expense of building it I hope I can afford to run at least one race this year, It's a SVO. Quote Link to comment Share on other sites More sharing options...
pederb Posted June 23, 2006 Share Posted June 23, 2006 My car is running and almost ready for tech inspection, after the expense of building it I hope I can afford to run at least one race this year, It's a SVO. Details, please Quote Link to comment Share on other sites More sharing options...
mikef Posted June 23, 2006 Share Posted June 23, 2006 Uh oh, tech director wanting details, I just have to finish the bulkhead between the fuel cell and the pass compartment, install the fire ext and label the master batt switch, otherwise it is a Griggs suspended car (older stuff) with a pretty much stock motor, just a few items, header, bigger intercooler, and larger injectors, right now with the stock doors (power windows) it weighs 2680 so I figure dial back the boost to the 280 hp level and see how bad the high power V8s tromp me, my only chance will be at tight tracks like Buttonwillow, at Willow springs a big HP track i will just be a back marker.within the next 30 to 60 days I hope to be ready for tech. Quote Link to comment Share on other sites More sharing options...
JKnight Posted June 23, 2006 Share Posted June 23, 2006 MikeF, 2680 with or without driver? And do you have any pictures? Jason Quote Link to comment Share on other sites More sharing options...
pederb Posted June 23, 2006 Share Posted June 23, 2006 Are you from Cali? Please add were you are from in your profile, that applies to everyone. Quote Link to comment Share on other sites More sharing options...
mikef Posted June 23, 2006 Share Posted June 23, 2006 (edited) Sad but true, 2680 without driver, yea I know I should be able to get it lighter than that, and I am working on that, I am no better than a V8 car, I can only hope the balance of the car is a little better, pictures, why it is just a fox body with a wheezy turbo 4 cyl, it has horrible lag, then goes from 90 hp to 300 hp in the blink of an eye, road racing a 2 wheel drive turbo car is very hard, it has a powerband like a 2 stroke, add the fact that it is a early 80s primitive EEC4 car, in fact one of fords 1st efforts at efi which is really a handfull when exiting a turn under lag oh i mean boost oh s#!t the rear bumper is leading, ok lift, oh no more lag oh wait it's under boost again, hurry lift before the rear bumper gets by again, this thing is pretty funny to drive, if i can ever get a reasonable power curve out of it, it might run ok, this was not my 1st choice in cars, it was just so cheap i wasnt going to pass it up. I will try to load some pics. Edited June 23, 2006 by Guest Quote Link to comment Share on other sites More sharing options...
mikef Posted June 23, 2006 Share Posted June 23, 2006 Hey, how do i post pics anyways? Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted June 23, 2006 Author Share Posted June 23, 2006 You can email them to me and I will host and post them for you. [email protected] Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted June 26, 2006 Author Share Posted June 26, 2006 Nice ride Quote Link to comment Share on other sites More sharing options...
V8cobra99 Posted June 26, 2006 Share Posted June 26, 2006 Nice ride for sure.... gut those doors..... !! that will save 40+ lbs per door.... andy Quote Link to comment Share on other sites More sharing options...
pederb Posted June 27, 2006 Share Posted June 27, 2006 Do I see a hydralic hand brake? Hmm, someone wants to go drifting I think Quote Link to comment Share on other sites More sharing options...
mikef Posted June 27, 2006 Share Posted June 27, 2006 It was just so much lighter than the stock handbrake, cables and brackets i couldent resist, besides the car was missing the cables, and drifting looks pretty cool, but I would need a tire sponsor 1st. Quote Link to comment Share on other sites More sharing options...
trackboss Posted June 27, 2006 Share Posted June 27, 2006 How did you attach the shift linkage at the transmission? Looks like a rod end, but to be effective it must be some sort of solid link to allow side to side movement for proper shifting? Closer photo? Quote Link to comment Share on other sites More sharing options...
mikef Posted June 27, 2006 Share Posted June 27, 2006 yes it is a rod end at the bottom, and the upper link has 3 small bearings stacked and pressed in a sleeve at each end with a shoulderd bolt, this was a quick slap together to see if it would even work (notice the lack of paint) but I am happy with it, the total throw is 2.75 1st to 2nd I was concerned that the upshift into 3rd would be difficult, so far it seems ok I might lower the upper link at the handle or raise it at the trans to reduce the ratio down to get 3.5 or 4" travel, the best part is the handle goes straight foreward and back, not up and down like a extended handle on a stock shifter, I cant load pictures, but I could send some to somebody who could. Quote Link to comment Share on other sites More sharing options...
mikef Posted June 27, 2006 Share Posted June 27, 2006 I have to add the upper link is the most important part, it has to zero side to side movement, I might consider a bushing instead of bearings, a very tight bushing, and the lower pivot must be on the same plane as the shifter pivot in the trans, otherwise it wants to bind up. Quote Link to comment Share on other sites More sharing options...
trackboss Posted June 27, 2006 Share Posted June 27, 2006 What about the link at the shifter? Quote Link to comment Share on other sites More sharing options...
mikef Posted June 27, 2006 Share Posted June 27, 2006 both of the ends on the upper link have bearings in them, they are the 3 small ones stacked and pressed into the sleeves, with the shoulderd bolt, If you are thinking of building one i would consider two links, one on each side of the handle and the shifter sticking out of the trans, that would be a more robust setup, and i would use a nylatron or some fairly hard bushing material, make the fit tight, so you reduce noise and vibration up through the shifter, the long bracket that i made that bolts to the two bolts on the trans is not thick enough .500 it flexes a little pulling into 2nd gear (downward) Quote Link to comment Share on other sites More sharing options...
horsewidower Posted July 25, 2006 Share Posted July 25, 2006 You're going to beat me to the track. We probably won't make a race this year, we hope to test at Thunderhill on Nov. 24th. I just got it back from the fabricator with everything finished but some paint, minor wiring, final "nut and bolt" and mounting the lexan windows. I'll get it on the scales this weekend, if its not 110 out, and see what it weighs, hoping to be about 2300 dry. We plan to take it to the dyno in mid-September to fire up the ECU and get the mule motor running. Bob Quote Link to comment Share on other sites More sharing options...
mikef Posted July 26, 2006 Share Posted July 26, 2006 turbo or n/a?, I hope you get down to 2300# I came in heavier than I hoped, and the whole idea is about a light weight, well balanced car, Quote Link to comment Share on other sites More sharing options...
mikef Posted July 26, 2006 Share Posted July 26, 2006 OH, and by the way I might not make it before you, I am having engine management problems. Quote Link to comment Share on other sites More sharing options...
horsewidower Posted July 27, 2006 Share Posted July 27, 2006 Turbo. What are you using for engine management? Quote Link to comment Share on other sites More sharing options...
