fast_frank_d Posted June 26, 2006 Share Posted June 26, 2006 Hello all, I'm prepping a 1990 mustang for HPDE duty and will be upgrading to SN95 5-lug disc brakes and 17x9 rims. Does anyone here have experience with this upgrade? If I pick the right parts to retain the original track width, will OEM 94+ Cobra wheels work? If I go aftermarket, what backspacing/offset am I really looking for? Thanks for listening.... Frank D. Quote Link to comment Share on other sites More sharing options...
Greg Collier Posted June 26, 2006 Share Posted June 26, 2006 I'm pretty sure stock it's +24mm which almost puts the face of the hub in the center of the wheel. Quote Link to comment Share on other sites More sharing options...
runningmole Posted June 27, 2006 Share Posted June 27, 2006 Try to get some 96+ spindles too. Better Ackerman. You'll also need a .330 ( i think) spacer. Quote Link to comment Share on other sites More sharing options...
fast_frank_d Posted June 28, 2006 Author Share Posted June 28, 2006 Thanks for the tips guys. The search begins... FD Quote Link to comment Share on other sites More sharing options...
runningmole Posted June 29, 2006 Share Posted June 29, 2006 You could probably piece it together for pretty cheap. Check out the classified section on http://www.corral.net I had mine done for less than $500. I used Ranger axles (I don't remember which side, but I think it's drivers). Ranger axles are the same length as stock 4 luggers. You can also use SN95 axles, they're slightly longer. V6, GT and Cobra rear calipers are nearly the same. You'll have to do a tiny bit of grinding on teh GT/ V6 (Varga) caliper. I have 01 Cobra calipers/brackets in the front. I don't remember what Master Cylinder is on my car. I still have the stock booster. They pedal is firm, and easily to modulate. Mine is a little soft at low rpm, but that's because of my cam Quote Link to comment Share on other sites More sharing options...
jfranci3 Posted June 29, 2006 Share Posted June 29, 2006 Definately check http://www.Corral.net/forums . They'll have all the info. In particular, check the Road Race forum Quote Link to comment Share on other sites More sharing options...
fast_frank_d Posted July 4, 2006 Author Share Posted July 4, 2006 I went to Corral and found some great info. Thanks for pointing me in the right direction. FD Quote Link to comment Share on other sites More sharing options...
Gary McDaniel Posted July 20, 2006 Share Posted July 20, 2006 Give Richard a call at 816 436 1610 for advise and look at his brake bracket set up to accomplish just what you are trying to do. He sells a ton of his conversion brackets, or check out his site at http://www.northracecars.com Quote Link to comment Share on other sites More sharing options...
