Mule Posted June 6, 2003 Share Posted June 6, 2003 SpeedStyle, I figured you ran with those gadgets off. A good driver will always out perform those gadgets and you are obviously a good driver. I mentioned that earlier directed toward us newbies. (Blue Z06 in HPDE 2) I drive a better line and couldn't keep up. Subies at Mid-Ohio, same thing. I am actually glad I am learning without those crutches. I realize I will be a better driver in the end. I run at Gingerman in July next. I just got the car back, Eibach springs installed, sticky tires, and 1.9 degrees negative camber. What a difference! The car sits an inch lower, and negative camber will help me keep that 3400lb pig from tracking out too hard at 120+. Quote Link to comment Share on other sites More sharing options...
