PapaJohn Posted February 7, 2004 Share Posted February 7, 2004 I want to enter an HPDE event at Cal. Speedway but have a tech concern: '94 T-Bird 4.6 supercharged, Cobra T-45 trans. I have a bolt in roll bar-one piece main hoop, diagonal bar, two bars going to the wheelwells and a bar from the top of the hoop to a 2"X1/8" sq> bar which spans the rear shock towers. Also a bar behind the seats where the Simpson 5 point harness wrap attaches. The seats are Corbeau and attach at the stock floor points--they do recline a bit. Is this setup ok? I run autocross and this setup prevents any body movement. Quote Link to comment Share on other sites More sharing options...
z28racergirl Posted February 7, 2004 Share Posted February 7, 2004 I think this has been addressed on this forum, have you tried a search? I'm not the tech person but I believe a roll bar, harness, and then a two-piece seat is a no-no. Try a search of the forum. Christine Quote Link to comment Share on other sites More sharing options...
JoeLee Posted February 7, 2004 Share Posted February 7, 2004 If you run stock or non-FIA seats with a rollbar or cage you MUST be sure that in NO EVENT can a seat collapse backward UNDER the rollbar. This could break your neck or back. Basically this means you need a seat back brace or the bulkhead to prevent rear seat movement. Harnesses are fine - as long as they meet Comp Spec per the CCR (EXCEPT the date rules - they just have to be visually ok for HPDE) Quote Link to comment Share on other sites More sharing options...
