Apex SPG.com Posted July 13, 2006 Posted July 13, 2006 Can someone explain what valve and seals (including part numbers) I will need for this upgrade? I am exchanging the stock oil cooler on a 1988 924s for a 944 turbo oil cooler. Thanks in advance to everyone who responds. Jim Quote
944-Spec#94 Posted July 14, 2006 Posted July 14, 2006 There are no special seals as the turbo stuff is direct bolt on to the NA block. If you are getting used turbo parts the only issue is making sure you have similar Oil pressure relief valve set-up. since you have an 88 924S ideall you'd want and 87 and later turbo oil filter hsg. If you have that it should bolt up easy. Quote
