VW JETTA VR6 EX-WORLD CHALLENGE/NASA GTS-$5500
Posted (edited)
-seme welded body by hsmracing
-custom strut towers for more shock travel by hsmracing
-chasis was sand blasted and re-painted
-front lexan windshield
-ground control camber plates
-advance desing shocks 2 way adjustable
-eibach springs
-solid bushings and poly urathen
-17/8 konig wheels 6
-1" spaicers front and back
-willwood 4 piston front calipers 12/5 front rotors and custom hats by hsmracing (hawk front racing pads)
-sloted rotors on the back(porterfield racing pads)
MOTOR WAS BUILT BY HSMRACING
-13-2-1 compression
-500 lift on the cams two sets
-wiseco pistons
-titaniun valve spring retainers
-longer valves(same size) to run with solid lifters
-CHOICE TO RUN SOLID LIFTERS OR HYDROLIC
-oil cooler
-custom radiator lowered to 4" from the ground for better center gravity
-motor was lowered and push back a few inches
-solid motor mounts by hsmracing
-custom headers by hsmracing
-dta engine management
-custom sheet metal intake manifold (one of the kind) by hsmracing
-custom final drive 4.88
-custom 1to 5 gears
-kaaz diff adjustable
-3 poke clutch
-10lbs flywleel
-chromolly cage(this is what holds the ball bearings) on the axle
-10 lbs fire system
-vdo gauges
-hpm wing
-unorthdox pulleys
  • 4 months later...
Posted (edited)
PRICE $5500 CAR HAS TO GO NEED SPACE FOR NEW PROJECTS.
THIS CAR CAN BE USE FOR NASA GTS OR USTCC
[email protected]
516.883.2470
at that price it's a steel!!! I don't have room for another race car, and my wife would kill me. Someone should jump on this.
  • 4 months later...
I'm parting out the car so if anybody wants something from this car just let me know
I can't believe no wants to buy this car for the money your asking!
Interested in an s2k?
Well it's a long story but at this point i don't have the time or the space to keep this car so i'm giving it one more chance
  • National Staff
Did you try Ebay?
I'm not usually one for suggesting something like this go on Ebay, but for that price with those pics, I can't see how you wouldn't get at least what your asking for in here!
Car is a steal.. Good luck with the sale.
I swaer If I was not knee deep in BS with my HC4 car I would so drive out and buy this tomorrow!! .. Im never going to build a race car again!! ..
I'd love to have this car too, but I'm a couple thousand miles too far away and a couple thousand $$$ short. Timing and location never seem to be my friend.
  • 3 weeks later...
car still located in NY?
Yes the car still located in long island new york
