loren fancy Posted May 31, 2024 Posted May 31, 2024 1991 acura integra h2 prepped b18c with b16 trans, nasa and scca log book. obd1 hondata s300 with spare, motor prepped with nsx injectors, fresh dizzy with all honda parts, ngk wires, 1" match port, angle cut prepped valves with I14 high rev springs, skunk2 intake with type r throttle body, oil pump and water pump, adjustable cam gears, remote oil filter, oil cooler, catch can, valve cover and crank case breathers, walbro fuel pump, fuel reg and gauage, cold air intake, crank balanced to clutch, header, aluminum polyurethane mounts, light crank pully, b16 trans with mfactory lsd and final drive, synchrotech carbon synchros, gsr shifter, raxels axles,exedy clutch,pressure plate and aluminum flywheel, sperical radius arms, LCA's, hardrace upper control arm, rear toe and camber arms, wilwood front brakes, koni 2812 shocks, arp wheel studs, 16" RPF1 wheels stoptech brake lines, rear lower sub frame brace, 3pc rear sway bar, stock front, dc rear strut bar and shunk2 front strut bar, racetech seat, fire bottle fire system, hard wired transponder, carbon hood, polycarbonate lexan side window and hatch, rear wing, splitter, clean body and paint....will need new belts and window net for annual. Quote
b16vtek Posted October 15, 2024 Posted October 15, 2024 Did you end up selling this? I have seen it a couple times on FB marketplace. Quote
