DaWorstPlaya Posted August 2, 2006 Posted August 2, 2006 Hi All, I've been trying to figure out how many points the coilovers I am thinking about getting for my car are going to cost me. Mind you these coilover are mainly a street/track coilovers that do not have very aggressive spring rates: http://www.z1auto.com/prodmore.asp?model=evo&cat=handling&prodid=1888 430lb.in front, 460lb.in rear, mono tube height adjustable and 9 way single adjustable http://www.z1auto.com/prodmore.asp?model=evo&cat=handling&prodid=2007 515lbs front, 340lbs rear, height adjustable and compression and rebound adjustable http://www.vishnutuning.com/evo_ohlins_coilover.htm 450lbs front, 550lbs rear, mono tube height adjustable and single adjustable I would like to go with the ones that only cost me 7 points as opposed to 12 points. I mean it's not like these are 3-4 way adjustable coilovers with extremely high spring rates. Thoughts? Thanks Quote
