1997 Honda Civic Racecar for sale.
1997 Honda Civic HB built to NASA HC1
Original owner, clean title, currently registered as non-operation In California.
Engine / Transmission
B16A block 0.25mm over bore
Honda CTR piston 0.25mm OS. 11.7:1 CR
All Honda bearings and seals
balanced Rod/Piston/Rings/Pin
6mm shimmed oil pump
Alaniz full race spec port/polish Head
custom Titanium valve retainers
Honda ITR Intake/Exhaust valves
Spoon Intake/Exhaust cams
Skunk2 cam adjustable sprockets
Honda ITR intake manifold
Spoon 70mm Throttle body
Spoon spark plug wires
Spoon muffler with custom piping
Iceman intake
Hondata custom intake gasket
Mugen CTR stainless exhaust manifold (severely scraped at bottom)
lightened Honda crank pulley
Honda P28 remapped ECU
Toda racing flywheel
Honda ITR oil cooler
Integra GSR transmission
Honda ITR LSD
Honda ITR 4.785 final drive
208 hp on 0 factory Bosch dyno with 9500 rpm cut off
Suspension / Brakes / Wheels / Tires
15x7 A-tech Finalspeed wheel
225/45-15 Hoosier R3S04 (20% left)
ARP extended wheel studs F
Spoon race dampers height/dampening adjustable
Spoon race springs F 14kg R 16 kg
Honda ITR Rear swaybar
Skunk2 camber kits F+R
Honda CTR Front lower arm
Energy suspension bushings in front
Energy suspension engine mount
Integra GSR brakes F+R
Integra GSR brake booster/master cylinder
Goodridge stainless braded brake lines
EBC green Front brake pads
Endless MA22 Rear brake pads
Chassis / Misc
Japan Civic One-Make-Race FIA 6 point roll cage (by CARROSSER Co, Ltd/CUSCO) with added diagonals for NASA and SCCA.
Honda CTR aluminum driver side mount
5Zigen prototype dry carbon front strut
5Zigen aluminum driver heel plate
Bride Zeta II racing seat
lightened hood with pins
12 lb battery mounted on passenger side floor
Momo steering wheel/ hub adaptor
JDM folding side mirror
air jack ready
2100 lb.
asking $10,000 OBO
What you will need before racing:
1. new safety belts
2. new window net
3. new fire extinguisher
Please contact me with your questions at:
[email protected]
Or
[email protected] (during lunch or after 5pm)
Thank you very much!
ps. I will take some pictures and post them up soon.
