944 cup Posted August 10, 2006 Posted August 10, 2006 (edited) The car is an '84 and in very good shape. Highlights: Full custom roll cage welded Accusump (3qt) Aux. Oil cooler New engine seals and rod bearings Balanced pistons and rods Fresh valve job. Fuel cell Koni double adjustable strut inserts in custom made housings w/400 lbs springs Koni aluminum body double adjustable rear shocks 28mm Torsion Bars Solid rear suspension mounts Aluminum rear trailing arms 22mm adjustable rear sway bar 27 mm Front sway bar All polyurethane bushings Ground Control camber plates Strut brace (stainless) Manual steering rack Momo steering wheel. Window net Seat back brace Corbeau race seat 5 Pt- race belts Kill switch Fire Extinguisher Fresh Kuhmos race tires Numeric oil and water temp guages and oil pressure guage Fuel pump switch Asking $11,000 for car and trailer. Trailer is a 2004 Master Tow with electric brakes and removable fenders, bearing buddies, with about 2,000 miles. GVWR 7,000lbs. Contact Dave at: [email protected] Edited August 13, 2006 by Guest Quote
944 cup Posted August 13, 2006 Author Posted August 13, 2006 And here are a few more items the car is equipped with: Performance header New custom free flow exhaust system AC Delete All new belts and hoses SS Brake lines front and rear New front control arms and ball joints New CV joints Quote
