99HOSS Posted February 14, 2004 Share Posted February 14, 2004 ... this is for a friend who drives in several different series ... The is a brand new Simpson Speedway VUDO - shell - This helmet is a INDY SPEC, and is not an off the shelf helmet. THIS IS THE BEST RACING HELMET AVAILABLE...and only available to pro drivers. It is lighter and stronger than the off the shelf VUDO. The helmet is size 7 1/4. The shell is primer color and needs to be painted, get it painted and then it is sent back to Simpson and the padding, HANS mounts and visor are attached. The helmet comes with a helmet bag and two visors (clear and tinted). This is the TOP OF THE LINE HELMET worn by Sam Hornish Jr, Gil de Ferran, and many other pro open wheel drivers...and is not availble over the counter... IN RACING YOU SHOULD USE THE BEST SAFETY EQUIPMENT YOU CAN AFFORD....THIS IS THE BEST HELMET ON THE MARKET.... * Aerodynamic Counter Measures, BLD, and Downforce Chime interact to control air flow to reduce lift and buffeting * Total cool air circulation system with adjustable forehead vents and air ram ducts * Complete with two .125" Lexan shields (Smoke & Clear) * Simpson's exclusive impact absorbing one-piece EPS liner with form fitting Nomex® lining * Twin Shield tabs * Snell SA approved Asking $ 650 or best offer email me at: [email protected] Quote Link to comment Share on other sites More sharing options...
