Spec Iron Eligible Wheels and tires
As it appears that the 07-09 gt500 wheels are the recommended setup for spec iron are no longer available to buy new.. seems on ebay a set is going for 3 grand!
anyone have any suggestions for aftermarket or factory wheel and tire setup which would also accommodate the 4 piston brembos?
Thanks
  • National Staff
Here is the wheel rule:
7.2.Tires/Wheels
The Toyo Tire RR and RA1 in 275/35ZR18 are the only tires permitted. Tire shaving is permitted. No other tire modifications are permitted. (i.e. - no tire grooving or chemical tire traction treatments) Aftermarket wheels are permitted. Wheels may not be modified. Wheels must be 18x9.5 and must weigh a minimum of 26.0 lbs. The Ford Racing M-1007-S1895 wheel is strongly recommended.
Maybe try this website?
https://www.fitmentindustries.com/store/wheels/18x9.5
