Sterling Doc Posted October 10, 2006 Posted October 10, 2006 I purchased this car this spring, and loved it, so much that I want to go spec 944 racing. To that end the car has been gutted, cat removed, & Lexan side windows put in. Unfortunately I've recently learned that the .5mm overbore that the car had as part of a 4K motor rebuild is illegal in spec 944. I've decided to go out and look for a built car instead of pulling the motor and finishing the build on the 924S. Therefore the 924S has to go. The car has no issues, and has run fawlessly for me through the summer. It's now down to 2,350 lbs, and is quite fun to drive in autocross or trackday events. Due the 924/944's spectacular balance/handling, it is very quick, while still being easy on tires & brakes - great budget racer. While it still has plates and a current street regitration, it's has no cat and is therefore not technically street legal. Very solid car, very tight, no rust. The car has a 3" stack of records and receipts from the prior 2 owners - Highlights: $4k+ motor rebuild at 137,000 miles (chassis has 173K miles). New susp. bushing and Koni yellow struts put in around that time. New water pump last year. Slotted, cryo treated rotors & HP + pads this year. I will sell the car for $4,000 with stock seats & steering wheel (not pictured) The Recaro SPG seats, Momo steering wheel & Sabelt Harnesses cost me a bundle, so I would like to keep them, but would consider selling that as as package for $1750 (seats alone cost me more) The car will be at the October NASA event at Road America. I will store the car indoors over the winter for free if needed. Quote
Sterling Doc Posted October 22, 2006 Author Posted October 22, 2006 Car has run great at Road America, but now needs rotors all aroungd. $3,500 as is is, or I will redo the brakes. Quote
