carbineguy Posted October 23, 2006 Posted October 23, 2006 I was hopefull someone could tell me yes or no for sure? I really do not see a clear answer in the rules, but it could be I'm missing it(wouldn't be the first time). Thanks for any help! Quote
BrianZ Posted October 23, 2006 Posted October 23, 2006 H4 is a limited prep class.. In short, No you cannot use any other glass that OEM (or OEM equivalent). In the rules is says "If these rules do not expressly state a modification is allowed, it is prohibited." The only place It says in the limited prep class about glass is 7.10 Body a) Vehicle bodywork must remain stock except for the following: 13) The Del Sol is allowed to remove or replace the rear window with Lexan in order to accommodate rear roll bar braces. This body modification is for the sole purpose of rear roll bar brace installation. Quote
carbineguy Posted October 24, 2006 Author Posted October 24, 2006 I knew I had seen that in there before but was missing it this time for some reason!! Well looks like another OEM windshield will go in(another loss to a rock). Thanks for the help guys!!! Quote
BrianZ Posted October 24, 2006 Posted October 24, 2006 No problem.. that is what the forums are for! Quote
